70 Cuda rocker gill paint #878736
12/13/10 12:27 AM
12/13/10 12:27 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Does anyone have suggestions on the right paint to use after you have repainted the silver rocker gills to redo the black lines separating each gill? I tried SEM Bumper Coat; sprayed some into a container and trying to brush it on those edges, but it was too thin and watery, didn't look good at all so I need another idea....thanks...
Re: 70 Cuda rocker gill paint [Re: redwrydr] #878737
12/13/10 01:24 AM
12/13/10 01:24 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
I used Testors flat black model car paint. If anyone tells you to paint the gills black first and then spray the silver at an angle, don't believe them. Ask me how I know!
Re: 70 Cuda rocker gill paint [Re: sixpaktoogo] #878738
12/13/10 03:27 AM
12/13/10 03:27 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Hmmm yes, looks like you know ...I sympathize, I was told to paint the silver and then tape each gill off and spray the bumper coat to get the black back...I was pretty sure that would be a train wreck, but just thinking about taping all that twice was enough to try to get me to steady my painting skills. So with the Testors, has it been durable for use outside? Not that I am going to treat it to harsh weather, but just wondering how tough it seems for outdoor use. How long have had your paint on and have you had any probs? Thanks much!
Re: 70 Cuda rocker gill paint [Re: redwrydr] #878739
12/13/10 08:28 AM
12/13/10 08:28 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I sprayed primer, masked it, then BLACK, and then....
Re: 70 Cuda rocker gill paint [Re: jbc426] #878740
12/13/10 08:31 AM
12/13/10 08:31 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes, it's true....sprayed it dull stainless from Krylon.
Re: 70 Cuda rocker gill paint [Re: jbc426] #878741
12/13/10 08:37 AM
12/13/10 08:37 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Surprisingly, the Krylon was almost a dead on match. It's kind of hard to see here, but if you look closely on the part on the right, you can see the original silver color down in the low-spots. The first three ridges are sprayed with Krylon dull stainless, and you can't tell the difference when looking at the two colors in person. The parts in the middle and on the left are primed, their black slits painted and are waiting to be remasked a finish coat of dull stainless applied.
Re: 70 Cuda rocker gill paint [Re: jbc426] #878742
12/13/10 08:49 AM
12/13/10 08:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The black stips look white in this picture because of the reflection, but the edge lines between the colors came out looking like the oiginal parts.
Re: 70 Cuda rocker gill paint [Re: redwrydr] #878743
12/13/10 09:28 AM
12/13/10 09:28 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Haven't had the car outside yet, but there shouldn't be a problem, since the Testors is enamel.
Re: 70 Cuda rocker gill paint [Re: jbc426] #878744
12/14/10 02:55 AM
12/14/10 02:55 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Looks good....thanks for the pics and info!
Re: 70 Cuda rocker gill paint [Re: sixpaktoogo] #878745
12/14/10 02:57 AM
12/14/10 02:57 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
OK...that makes sense....thanks much!
