Re: 0 deck, any power to be had? [Re: Tiger Core] #878678
12/15/10 10:18 PM
12/15/10 10:18 PM
UK
602heavy Offline
602heavy  Offline
UK
Thanks for posting Tiger , some interesting reading there.
Can you explain some more regards piston 5mm above deck & effect on head gasket? , are you saying the piston acts as a shroud of some sort?
Thanks again.
Re: 0 deck, any power to be had? [Re: 602heavy] #878679
12/17/10 01:51 AM
12/17/10 01:51 AM
California, USA
Tiger Core Offline
Tiger Core  Offline
California, USA
Thanks again.
Hello fellow Brit!
To reduce the strain on the cylinder head gasket the pistons intrude by about 5mm into the head, so as to cover the gasket area at top dead centre where pressure and temperature are highest. The gasket is made of a spring steel recessed in a groove in the upper flange of the cylinder. The head is machined accordingly
Re: 0 deck, any power to be had? [Re: Tiger Core] #878680
12/17/10 10:05 PM
12/17/10 10:05 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
OK lets add this question. Aluminum rods need more piston to head. This has been discussed before. It varies with the type of rod,weight ,RPM,etc. Lets say the combo requires .060" piston to head. How much quench distance is there while the engine is running? If the piston touches the head at .057" do I have effective quench?
Doug
Re: 0 deck, any power to be had? [Re: dvw] #878681
12/17/10 10:26 PM
12/17/10 10:26 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Doug
Absolutely, Why wouldnt it?
Re: 0 deck, any power to be had? [Re: Sport440] #878682
12/17/10 11:11 PM
12/17/10 11:11 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Another source of miniscule power "loss" would be the dead space above the top ring. With a piaton below deck, the ring is down further in the bore (assuming identical ring placement on the two comparable engines' pistons) and that will allow air/fuel to be trapped there and not burn. I routinely run pistons at .005" above deck, mainly because I want .030-.035" quench distance with the Felpro .039 gaskets. You also want to minimize the chamfer on the top of the bore as this too can work as "dead volume".
On the aluminum option, you have to maintain some distance between the piston and head, but some of the fastest engines I know of just touch at very high rpms. Just enough to leave a mark. The less "dead space" you have in the chamber the more mixture gets burnt completely and more power is realized.
Re: 0 deck, any power to be had? [Re: Sport440] #878683
12/18/10 12:07 AM
12/18/10 12:07 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Doug
Heat soak with alu rods before you make a pass and the quench should be close to a steel rod engine, most alu rods need hot oil before you load them up anyway
Re: 0 deck, any power to be had? [Re: emarine01] #878684
12/18/10 02:00 PM
12/18/10 02:00 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'm not way into aluminum rods but from what I know they are very elastic and they will stretch as the piston changes direction at TDC.. They do grow in length (and in term compress) while running hard even after reaching operating temp. The temp thing is more about stabilizing the oil temp and it's ability to do it's job.
Re: 0 deck, any power to be had? [Re: Tiger Core] #878685
12/18/10 09:26 PM
12/18/10 09:26 PM
UK
602heavy Offline
602heavy  Offline
UK
Thanks again.
Hello fellow Brit!
Thanks.
Some guys on here would'nt have bothered answering seeing as i come from little ole UK. , or they got us on 'ignore this user'
Re: 0 deck, any power to be had? [Re: 602heavy] #878686
12/18/10 10:11 PM
12/18/10 10:11 PM
California, USA
Tiger Core Offline
Tiger Core  Offline
California, USA
Thanks again.
Hello fellow Brit!
Thanks.
I wouldn't worry too much. Most Americans treat Brits extra special- specially the ladies. Those blokes that don't are usually bitter that we're nicking all their women and I'm ok with that
