Re: 0 deck, any power to be had?
[Re: mopar dave]
#878659
12/12/10 11:48 PM
12/12/10 11:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Sure if you have unburnt fuel due to bad combustion you stand to have predetonation on the next firing cycle. This is a negative force trying to push piston down when momentum is moving the piston up.
This is one of the areas of attack I am doing on a stock build. Not looking for power but wanting fuel economy. Power will just be a bonus.
Leon
[Re: ahy]
#878663
12/13/10 02:07 AM
12/13/10 02:07 AM
Posts: 5,080 organ
maximum entropy
organ
it is definitely worth it. at the very least, the engine will be less prone to detonation. at best, the engine will be less prone to detonation AND you'll go faster. this assuming that your compression ratio and cam are compatible.
[Re: Baxter61]
#878670
12/15/10 04:54 AM
12/15/10 04:54 AM
Posts: 9 California, USA
Tiger Core
California, USA
does anyone know of any tests done to test this theory? just curious because the shape of .020 of bore could affect the flame front differently from seeing that .020 in a head gasket correct? not saying would, just saying could. be an interesting test to see none the less
I've tested this but in a laboratory and not on a Mopar engine or in terms of drag times, unfortunately. It was during engine development for an Jaguar engine. Burn duration is measured in 10-90% burn time. What was found was that when the squish was maintained at 0.9 to 1mm (35 thou to 39 thou) there was a measurable improvement in burn duration of a couple of degrees. This manifested itself as less ignition advance required when optimised for best torque. Once squish clearance increased to 1.2 to 1.3 mm (47 to 51 thou) you ended up with a flame front quench zone which was detrimental to combustion (forming a rich pocket) and in some cases was a source of detonation. Effective squish not only depends on the clearance but also the stroke length/mean piston speed. This means that squish is more effective on longer stroke engines, such as the older Jaguar AJ16 and less effective on the shorter stroke motors such as the Jaguar AJ26 V8. I would venture to say that it becomes more effective once a stroke length of greater than about 90mm is used. In our case our RBs have a healthy stroke of about 95mm as standard
[Re: Tiger Core]
#878671
12/15/10 05:18 AM
12/15/10 05:18 AM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
I wasnt referring to the squish itself but as to were its found. Such as a piston being .020 down in the bore and using a .019 head gasket vs. 0 deck piston and .039 head gasket, all else being equal.
[Re: Baxter61]
#878672
12/15/10 05:21 AM
12/15/10 05:21 AM
DaytonaTurbo
Manitoba, Canada
I've heard of guys doing it both ways and I really don't think you're going to see any measurable difference.
[Re: DaytonaTurbo]
#878673
12/15/10 05:36 AM
12/15/10 05:36 AM
Baxter61
Oregon City, OR
my thoughts also are that theres not much different, just curious if anyone has tested it to find out.
[Re: DaytonaTurbo]
#878674
12/15/10 05:38 AM
12/15/10 05:38 AM
Posts: 6,137 Melbourne , Australia
LA360
On the flip side I recall Jon Kaase running a thick head gasket with the piston crown out of the bore. Some of the engine master contestants have running some pretty tight quench in the past (around 0.030")
Alan Jones
[Re: mopar dave]
#878676
12/15/10 12:44 PM
12/15/10 12:44 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I Would venture that if the piston comes out of the bore the easier it would be to burn the top ring and also would be hard to run 36 to 38 deg total timing . The thicker the top ring land with cooling groves helps prevent detonation.
1969 Dodge Charger
1969 Dodge Superbee
[Re: Tiger Core]
#878678
12/15/10 10:18 PM
12/15/10 10:18 PM
Posts: 1,200 UK
602heavy
UK
Thanks for posting Tiger , some interesting reading there. Can you explain some more regards piston 5mm above deck & effect on head gasket? , are you saying the piston acts as a shroud of some sort? Thanks again.
[Re: 602heavy]
#878679
12/17/10 01:51 AM
12/17/10 01:51 AM
Tiger Core
California, USA
Thanks again.
Hello fellow Brit!
To reduce the strain on the cylinder head gasket the pistons intrude by about 5mm into the head, so as to cover the gasket area at top dead centre where pressure and temperature are highest. The gasket is made of a spring steel recessed in a groove in the upper flange of the cylinder. The head is machined accordingly
[Re: dvw]
#878681
12/17/10 10:26 PM
12/17/10 10:26 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
OK lets add this question. Aluminum rods need more piston to head. This has been discussed before. It varies with the type of rod,weight ,RPM,etc. Lets say the combo requires .060" piston to head. How much quench distance is there while the engine is running? If the piston touches the head at .057" do I have effective quench? Doug
Absolutely, Why wouldnt it?
[Re: Sport440]
#878682
12/17/10 11:11 PM
12/17/10 11:11 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Another source of miniscule power "loss" would be the dead space above the top ring. With a piaton below deck, the ring is down further in the bore (assuming identical ring placement on the two comparable engines' pistons) and that will allow air/fuel to be trapped there and not burn. I routinely run pistons at .005" above deck, mainly because I want .030-.035" quench distance with the Felpro .039 gaskets. You also want to minimize the chamfer on the top of the bore as this too can work as "dead volume".
On the aluminum option, you have to maintain some distance between the piston and head, but some of the fastest engines I know of just touch at very high rpms. Just enough to leave a mark. The less "dead space" you have in the chamber the more mixture gets burnt completely and more power is realized.
[Re: Sport440]
#878683
12/18/10 12:07 AM
12/18/10 12:07 AM
Posts: 3,695 nc
emarine01
nc
Heat soak with alu rods before you make a pass and the quench should be close to a steel rod engine, most alu rods need hot oil before you load them up anyway
[Re: emarine01]
#878684
12/18/10 02:00 PM
12/18/10 02:00 PM
moper
Columbia, CT
I'm not way into aluminum rods but from what I know they are very elastic and they will stretch as the piston changes direction at TDC.. They do grow in length (and in term compress) while running hard even after reaching operating temp. The temp thing is more about stabilizing the oil temp and it's ability to do it's job.
[Re: Tiger Core]
#878685
12/18/10 09:26 PM
12/18/10 09:26 PM
Posts: 1,200 UK
602heavy
UK
[Re: 602heavy]
#878686
12/18/10 10:11 PM
12/18/10 10:11 PM
Tiger Core
California, USA
Thanks again.
Hello fellow Brit!
Thanks.
Some guys on here would'nt have bothered answering seeing as i come from little ole UK. , or they got us on 'ignore this user'
I wouldn't worry too much. Most Americans treat Brits extra special- specially the ladies. Those blokes that don't are usually bitter that we're nicking all their women and I'm ok with that
