How much HP potential from 516 heads? #878368
12/12/10 07:05 PM
12/12/10 07:05 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I have a 440 and am considering what to do with it, I am a SB guy at heart and in practice. I know the 516 heads are not the best but just how much are you guys makeing useing them, either ported or untouched? I have my own valve grinder and the guides and stuff are fine so it would not be cost worthy for me to look for anything else.
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878369
12/12/10 07:09 PM
12/12/10 07:09 PM
AndyF Offline
AndyF  Offline
They'll work just fine for your tow truck.
Re: How much HP potential from 516 heads? [Re: AndyF] #878370
12/12/10 07:33 PM
12/12/10 07:33 PM
ohio
all spooled up Offline
ohio
NONE
Re: How much HP potential from 516 heads? [Re: all spooled up] #878371
12/12/10 08:48 PM
12/12/10 08:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
So this is a 516 Big Block head? The heads are key, but what is the rest of the engine?
Big diff in well ported 1.73 exh and 2.14 intake heads vs stock takes off's from a 67 383 with 1.6 exh valves.
Id say a moderate effort 400-450 hp should be rather easy with pump gas.
Re: How much HP potential from 516 heads? [Re: Bob_Coomer] #878372
12/12/10 09:22 PM
12/12/10 09:22 PM
Kalispell Mt.
Kalispell Mt.
Thanks Bob for the usefull answer.
400-450? Are they that bad? A SB can do that pretty easy with stock heads
The motor will be a 1967 HP short block with the deck milled to get zero deck piston height. For cam I was thinking something in the RPM and idle quality range of the comp XE268. Something like an eddy RPM intake. I can do some decent porting with some good instruction.
For a car I am looking for a short bed short cab dakota, aspen, volare mabey a 4dr dart or valiant.
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878373
12/12/10 09:30 PM
12/12/10 09:30 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Some excellent info from Engine Guru Fast68 :
http://www.moparts.org/Tech/Archive/bb/62.html
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878374
12/12/10 10:28 PM
12/12/10 10:28 PM
ill
dennismopar73 Offline
ill
well the good is mm closed chambered
mmm they will work on youre big block
mmm they look really good cleaned and painted
bad anything after the paint
dont flow ,, bad seats prone to cracking worse than 906s
take more money to make them anything
just get set 452s or even better set of eddies
or buy set of 440 so stuff
Re: How much HP potential from 516 heads? [Re: dennismopar73] #878375
12/12/10 10:30 PM
12/12/10 10:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
for what it's worth many years ago I ran 906,915,516 heads on the same 440 in my RR. car ran the exact same thing with all 3 different heads
Re: How much HP potential from 516 heads? [Re: Quicktree] #878376
12/12/10 10:46 PM
12/12/10 10:46 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
They should support 400 + hp fine, if looking for more than 450hp look for a 915 or aftermarket head
Re: How much HP potential from 516 heads? [Re: Quicktree] #878377
12/12/10 10:53 PM
12/12/10 10:53 PM
ill
ill
what ya race with is diffrent than you drive
on the street harden seats vs non hardened
i to have run em too,, but, wouldnt waste my time ,for a street motor , 452 way better set, not prone to crack as 516 /906 and that maybe 1/2 point of compresion means almost nothin
for money spent to even make em good
if they are the only head , if the car was a restoration peice, had then i would
i do agree all heads being the same
you re car prob did run the same
so that proves that point / or 1/2 point of comp didnt help those 516 over come their realy bad flow either
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878378
12/12/10 11:26 PM
12/12/10 11:26 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Not sure if I'm qualified to post in this forum, but.............
my 69 383 Rr ran 13.08 at 105, thru the muffs, pistons in the hole .070, with MP template ported, 2.08/1.74 valved 516's.
I'm sure them old "doorstops" were holding it back.
I always enjoy it when this topic comes up........
Re: How much HP potential from 516 heads? [Re: Dean_Kuzluzski] #878379
12/12/10 11:58 PM
12/12/10 11:58 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Dave I ran 516 heads last summer on a 426. I did put in the 1.74 exhaust valve and bowl cleanup. Was able to get 11.90 in a light car. I was just "killin time" till my new motor was ready. If there ready to run and all the budget will alow run em till you can get something better. If you have to spend any thing much at all on them I'd jump right to an Alum. head.
Re: How much HP potential from 516 heads? [Re: Maximus_Wedges] #878380
12/13/10 12:31 AM
12/13/10 12:31 AM
Kalispell Mt.
Kalispell Mt.
The deal is guys that I have thease heads, I do not have 915 452.... so I want to know how much potential thease have and what I can do at home to improve them, since I have a valve grinder and they need nothing but a quick VJ to run, probably would actually run fine as is but there is some very fine pitting on the seats. The guy was running them in a firewood hauling truck for years on 87 octane and the seats are not sinking, hardened seats are over rated on a mopar.
11.90 is good to me, no cage required and no $1000 set of heads.
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878381
12/13/10 12:35 AM
12/13/10 12:35 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If 11.90's would make you happy then run them or a mild 360 with stock heads. Lot's of choices.
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878382
12/13/10 01:26 AM
12/13/10 01:26 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
http://www.youtube.com/watch?v=HUBiQTvTF68&feature=related
The answer you seek is at the 38 second mark of this vid.
Will Darnell knew a thing or two about cars.
Re: How much HP potential from 516 heads? [Re: tubtar] #878383
12/13/10 01:43 PM
12/13/10 01:43 PM
Ky
moparmafia Offline
moparmafia  Offline
Ky
we have a set of 516's that flow 276 and went 5.90 in the 1/8 in a 68 charger @3500 lbs. with the help of nos of course. so you could say they work ok i guess.
Re: How much HP potential from 516 heads? [Re: moparmafia] #878384
12/13/10 02:42 PM
12/13/10 02:42 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
There was a Challenger from Texas that used to run in one of the NMCA classes in the 90's. Iron oem heads were required. I met the guy that ported the heads on that car. He claimed with a ported head he liked the 516 better as there was more meat to shape the ports to his liking. The Challenger ran at the top of its class. Had a wierd looking hood scoop on it. I will try to find some information.
Getting old just means you were smarter than some and luckier than others.
Re: How much HP potential from 516 heads? [Re: dannysbee] #878385
12/13/10 03:17 PM
12/13/10 03:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
before I snapped a valve my old 516's w/ 2.14/1.81 valves flowed around 270/180. I'm guessing the car would have been in the 11's easy.
Coming soon!!!!
Re: How much HP potential from 516 heads? [Re: Mr.Yuck] #878386
12/13/10 10:56 PM
12/13/10 10:56 PM
Kalispell Mt.
Kalispell Mt.
At 270 CFM that would be enough for aproximately 540 hp correct? That would definately be more than enough. Any one know how much they flow with no port work?
Re: How much HP potential from 516 heads? [Re: HotRodDave] #878387
12/13/10 11:03 PM
12/13/10 11:03 PM
210 to 220 at .500 lift with stock valves and no port work, according to Don Little a long time ago
