NOS turbo 440 manifold??? #878091
12/12/10 12:30 PM
12/12/10 12:30 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
There is one in the for sale section
When and on what did they do this??? Industrial application??
Re: NOS turbo 440 manifold??? [Re: joshking440] #878092
12/12/10 01:27 PM
12/12/10 01:27 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am guessing a late 70's motorhome.i remember seeing a cam for it in the PAW catalog in the 80's.i am useualy wrong tho.
found some pics here.
http://www.turbododge.com/forums/f11/f54/195565-turbo-440-rv-2.html
Re: NOS turbo 440 manifold??? [Re: blownzoom440] #878093
12/12/10 02:07 PM
12/12/10 02:07 PM
ELYRIA,OH
ELYRIA,OH
2
Re: NOS turbo 440 manifold??? [Re: joshking440] #878094
12/12/10 06:47 PM
12/12/10 06:47 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
RV's. they would work great on a something like I built. the trouble is getting them to fit a vehicle
Re: NOS turbo 440 manifold??? [Re: Defbob] #878095
12/12/10 08:37 PM
12/12/10 08:37 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I bet that heated the floors in the RV!
What type of Thermoquad was that?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: NOS turbo 440 manifold??? [Re: Rug_Trucker] #878096
12/15/10 12:58 PM
12/15/10 12:58 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Probably a standard T-quad. That RV setup is a draw-thru system, which typically does not require carb mods.
Air goes thru the carb into an adapterplate, thru the turbo compressor, and then back thru a separate chamber in the adapter plate and into the intake manifold.
Re: NOS turbo 440 manifold??? [Re: Fury Fan] #878097
12/15/10 11:35 PM
12/15/10 11:35 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Do you have to richen it up a bunch for the extra air?
How would a air/fuel mix work going into a intercooler?
Fuel fall out of suspension?
Re: NOS turbo 440 manifold??? [Re: Rug_Trucker] #878098
12/15/10 11:40 PM
12/15/10 11:40 PM
North Carolina
fastmopars Offline
fastmopars  Offline
North Carolina
Pic of the adapter plate..
Re: NOS turbo 440 manifold??? [Re: fastmopars] #878099
12/15/10 11:46 PM
12/15/10 11:46 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Looks like in runs in a circle
I remember the ACCEL Turbo systems back in the day. Reggie Jackson had a car with one IIRC.
Re: NOS turbo 440 manifold??? [Re: Rug_Trucker] #878100
12/15/10 11:50 PM
12/15/10 11:50 PM
North Carolina
fastmopars Offline
fastmopars  Offline
North Carolina
The bottom side..
Re: NOS turbo 440 manifold??? [Re: Rug_Trucker] #878101
12/16/10 05:07 PM
12/16/10 05:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You set it up like a normal carb but need to enlarge the needle and seat to allow more fuel flow.
They're great for fuel suspension. Most of the fuel gets mixed into a really nice aerosol. The down side is that if there's a leak you've got a fuel/air bomb on your hands. It's not possible to intercool and will ice the carb in cold weather.
- Stu Harmon
Re: NOS turbo 440 manifold??? [Re: feets] #878102
12/16/10 06:09 PM
12/16/10 06:09 PM
ELYRIA,OH
ELYRIA,OH
i dissagree on intercooling.it can be drawn thru an A/W like with the roots but would need fab work to mount it over the intercooler core.just saying.
ps:my brother made 300rwhp on a KZ1425cc MR turbo kit draw thru [correction[S&S flat slide 40mm.
Re: NOS turbo 440 manifold??? [Re: feets] #878103
12/16/10 08:08 PM
12/16/10 08:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought those were really terrible for fuel suspension because you need to drag the fuel all the way from the carb, to the turbo, then back to the intake manifold. That's a lot of area for the fuel to cool and fall out of suspension.
Re: NOS turbo 440 manifold??? [Re: blownzoom440] #878104
12/17/10 10:52 AM
12/17/10 10:52 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Draw cold air through an intercooler then compress it and heat it up again?
Yeah, that makes sense.
- Stu Harmon
Re: NOS turbo 440 manifold??? [Re: DaytonaTurbo] #878105
12/17/10 10:54 AM
12/17/10 10:54 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you have an overly rich condition you can actually spin the fuel out of the mix in the compressor. Keep the tubing runs as short as possible and you'll be okay with the mix under boost.
At cruise you certainly can have the fuel falling out.
- Stu Harmon
Re: NOS turbo 440 manifold??? [Re: feets] #878106
12/17/10 06:38 PM
12/17/10 06:38 PM
ELYRIA,OH
ELYRIA,OH
no SIR!the draw thru carb setup gets bolted on top of the A/W that is on top of the intake.
Re: NOS turbo 440 manifold??? [Re: blownzoom440] #878107
12/18/10 12:31 AM
12/18/10 12:31 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That would help but I feel sorry for anyone with a backfire. That IC would be a bomb!
- Stu Harmon
Re: NOS turbo 440 manifold??? [Re: feets] #878108
12/18/10 12:50 AM
12/18/10 12:50 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
NEVER done any tweaking on this set-up but I have heard some reports from guys who have had this combo in motorhomes......
GOT to run premium fuel ... and with the weak as-is 440 in a motorhome chassis .. you are always "in" the turbo boost.
It is not the type of combo I would want to have.
Re: NOS turbo 440 manifold??? [Re: feets] #878109
12/18/10 01:23 AM
12/18/10 01:23 AM
ELYRIA,OH
ELYRIA,OH
not to ramble on but if there was a 1 way flap in the tube a high back pressure could close the system before it got to the turbos/carb's
Re: NOS turbo 440 manifold??? [Re: dOoC] #878110
12/18/10 09:37 AM
12/18/10 09:37 AM
Rug_Trucker Offline
Rug_Trucker  Offline
I wouldn't think 6 pak rods would be necessary. Some did get them.
Cast pistons in there? I would want to run water/meth injection.
