1970 Cuda fog light and marker lights #877933
12/12/10 09:45 AM
12/12/10 09:45 AM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
Its it true that when the Road/Fog lights on a 70 Cuda come on the side marker lights should come on?
Re: 1970 Cuda fog light and marker lights [Re: jml19621] #877934
12/12/10 09:47 AM
12/12/10 09:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
or the opposite - you shouldn't be able to turn on the fog lamps unless at least the parking lamps are on.
Re: 1970 Cuda fog light and marker lights [Re: jml19621] #877935
12/12/10 01:42 PM
12/12/10 01:42 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Activating the roadlamps will indeed turn on the marker lights as well as the dash illumination circuit...
Re: 1970 Cuda fog light and marker lights [Re: screamindriver] #877936
12/12/10 05:14 PM
12/12/10 05:14 PM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
O.K. I have checked everything and it works as it should. I have seen pictures of the Road light wiring and set up, and I do now have another question. In the pictures I have seen, specifically on MOPARTS there is a relay. I have a place of such a relay, but I do not have the relay. If everything is working right what does the relay do?
Re: 1970 Cuda fog light and marker lights [Re: jml19621] #877937
12/12/10 05:38 PM
12/12/10 05:38 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The relay supplies power to the side marker and running lights when only the road lamp switch is turned on. It does not supply power to the road lamps, the switch does.
Re: 1970 Cuda fog light and marker lights [Re: Snoopy] #877938
12/12/10 08:42 PM
12/12/10 08:42 PM
Harrisburg, Pa.
Harrisburg, Pa.
So if everything is working as it should you've got the relay in place already or someone has rewired the circuits....Relay is positioned behind the ash tray area...
Re: 1970 Cuda fog light and marker lights [Re: screamindriver] #877939
12/12/10 10:38 PM
12/12/10 10:38 PM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
O.K. Thanks for the last picture, I see the relay I am missing is the buzzer one. Where can I get it and does any body have the part number?
Thanks for the help.
Jeff
Re: 1970 Cuda fog light and marker lights [Re: jml19621] #877940
12/13/10 12:07 AM
12/13/10 12:07 AM
Snoopy Offline
Snoopy  Offline
Check eBay, they show up occasionally.
