posi rear ? #87773
07/12/08 10:01 PM
07/12/08 10:01 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
I'm getting a thunk sound,but only when I'm making a turn.It's a 69 Charger with a dana 60 and 391's.Is it possible the oil is thickening and the slip (clutch plates?) is sticking? It's like it's skipping in the turn.
Re: posi rear ? [Re: tt455] #87774
07/12/08 10:35 PM
07/12/08 10:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it is a posi it may jump around cause that is a GM name. Mopar is a SURE GRIP. Did you sure grip friction modifier to the lube??.
Re: posi rear ? [Re: MoparforLife] #87775
07/12/08 10:56 PM
07/12/08 10:56 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Sorry,I'm a Buick guy asking for someone else.Traction-Loc,Sure Grip,Posi,I guess they all do the same.Thanks for the reply,I'll ask my buddy.
Re: posi rear ? [Re: tt455] #87776
07/13/08 09:46 AM
07/13/08 09:46 AM
scratchnfotraction Offline
a good working sg should be a little tight
inside tire should want to skip/shudder/spin a little bit in a real tight,slow turn
r&r the gear lube and add the aditive to the oil
are ya sure its not low on oil?
when was the last oil change for the chunk?
