Holley or Carter mech.fuel pump #877615
12/11/10 04:59 PM
12/11/10 04:59 PM
Seymour,IN.
HoosierGTX Offline OP
Seymour,IN.
Getting ready to put together a new street-strip 440,wondering what kind of mech. fuel pump is the one to go with these days? I have used Carter in the past with good results but that was 25-30 yrs. ago,any advice would be appreciated>
Re: Holley or Carter mech.fuel pump [Re: HoosierGTX] #877616
12/11/10 05:15 PM
12/11/10 05:15 PM
Renton Washington
Triple Threat Offline
Renton Washington
I've had a carter on my basic 12 second 340 for 5+ years, thousands of street miles and a lot of passes down the track. no issues.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Holley or Carter mech.fuel pump [Re: Triple Threat] #877617
12/11/10 05:33 PM
12/11/10 05:33 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I believe you can't go wrong with either one! I currently run a Holley 110GPH on my 11 sec. 440 GTX,and have never had a fuel-delivery issue at the track..or on the street for that matter!
Re: Holley or Carter mech.fuel pump [Re: Labratt] #877618
12/11/10 05:36 PM
12/11/10 05:36 PM
I use the standard Carter with no issues at all.6.0-6.5 psi.
They also make a higher PSI Pump up to 9 psi.
Re: Holley or Carter mech.fuel pump [Re: HoosierGTX] #877619
12/11/10 07:31 PM
12/11/10 07:31 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
I have a Holley mechanical on my brand x and I drive it every where and shift at 6,500 when I race it. No issues at all.
Re: Holley or Carter mech.fuel pump [Re: HoosierGTX] #877620
12/11/10 07:57 PM
12/11/10 07:57 PM
When I started racing NHRA stock( a long time ago ) we had a Holley mechanical race pump on the street hemi we where racing, it would lose fuel psessure from the start of high gear 6.5 lbs and drop down to 1.5 to 3.0 lbs at the finish line. It would surge a little now and then at the finish line. We took the car to one of Mopars drag clinics at the old Irwindale drag strip and told one of the Mopar drag reps about that, he suggetsed to switch it to one of the Carter NASCAR Hemi race pumps to cure the fuel pressure dropping. Dave Wren was at that test session and we bought a used one from him and installed at the track right away. That fixed the pressure problem and ended up helping the car go faster We had changed the stock jetting making it richer one size at a time on all eight barrels, the car went faster on the first change and didn't change after that until we changed the fuel pump Buy the Carter race pump and never look back, you may need to run a pressure regualtor also Some do and some don't, probally depends and the needles and seats your using
Re: Holley or Carter mech.fuel pump [Re: Cab_Burge] #877621
12/11/10 08:11 PM
12/11/10 08:11 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ive had the same problems only the other way around.. roll the dice. Buy the one you think will look the best.
Re: Holley or Carter mech.fuel pump [Re: Cab_Burge] #877622
12/11/10 09:06 PM
12/11/10 09:06 PM
That is exactly true.
Re: Holley or Carter mech.fuel pump #877623
12/11/10 10:48 PM
12/11/10 10:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I hear the airtex part store replacement is very good made in U.S., not sure how much HP or fuel line size but if your in the 400 to 450 hp range its probably fine.
