Help me get this header bolt out! #877539
12/11/10 04:10 PM
12/11/10 04:10 PM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
This is the last bolt I need to get out... 440 #2 cylinder. Hooker Super Comps. Tried a crow foot but the head is starting to strip. I do not have a torch. Would rather not destroy it/looking for a clean removal. So far I have tried (1) sliding the header forward (2) Needle nose Vise grips and a crescent wrench, (3)Crow foot, (4) Praying to higher powers including the Blessed Mother of Rapid Acceleration. Suggestions welcome other than dynamite (Had a bad experience with that)
Common sense is a flower that does not grow in everybody's garden
Re: Help me get this header bolt out! [Re: Ron_M] #877540
12/11/10 04:18 PM
12/11/10 04:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Are you trying to save those headers? If not, hacksaw, chisel or dent that thing out of the way.
Re: Help me get this header bolt out! [Re: Ron_M] #877541
12/11/10 04:20 PM
12/11/10 04:20 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I would try taking a long punch and denting that header tube in a little bit more so you can slide a narrow box end wrench over the bolt.
Stan
Re: Help me get this header bolt out! [Re: HemiStan] #877542
12/11/10 04:24 PM
12/11/10 04:24 PM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
Yes on saving the headers (I need the $$ to rebuild the engine) and I am afraid if I keep nailing that tube, I'll breach it but that is a suggestion I'll keep in mind and might even go try. Thanks!
Re: Help me get this header bolt out! [Re: jbc426] #877543
12/11/10 04:26 PM
12/11/10 04:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Use a 6 point box if you can get it in.I have some that are thinner than regular wrenches.That or try a 14 MM wrench.Its a bit smaller than what looks like a 9/16 head on that bolt.If you have a propane torch heat the bolt real good and melt some wax in there.Thats why I always antisieze my bolts.Rocky
Chrysler Firepower
Re: Help me get this header bolt out! [Re: jbc426] #877544
12/11/10 04:26 PM
12/11/10 04:26 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Cut the headers out with a sawzall. With a long blade you should be able to get in close to the flange. Then try a 6 point box wrench and heat.
Re: Help me get this header bolt out! [Re: Ron_M] #877545
12/11/10 04:29 PM
12/11/10 04:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Beefy-quality open end wrench. If that don't work, try sneaking a 12 point thin walled box wrench on it. It that don't work, just knock it around with a nice bity chisel. I think many here have a drawer full of stuff, stuff like random silly header bolts, that could be spared for you when you trash that one.
Re: Help me get this header bolt out! [Re: buildanother] #877546
12/11/10 05:31 PM
12/11/10 05:31 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
This is why you use header bolts....The one you are trying to remove is a regular bolt....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Help me get this header bolt out! [Re: Ron_M] #877547
12/11/10 06:48 PM
12/11/10 06:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you are going to rebuild the engine, then cut off the bolt head with a die grinder, the header will come off. Then remove the bolt from the head with the head on the work bench. Headers saved.
Re: Help me get this header bolt out! [Re: NANKET] #877548
12/11/10 08:51 PM
12/11/10 08:51 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
I have used ignition wrenchs before in low clearance situations with pretty good results.
Re: Help me get this header bolt out! [Re: Ron_M] #877549
12/11/10 09:01 PM
12/11/10 09:01 PM
NJ
440challenger Offline
NJ
propane torch, pb blast and a real good VICE grip and keep working it back and fourth
Re: Help me get this header bolt out! [Re: 440challenger] #877550
12/11/10 09:05 PM
12/11/10 09:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
mapp gas might even be better. Burns much hotter with the oxygen.
Next time maybe header bolts and anti seize.
Re: Help me get this header bolt out! [Re: bboogieart] #877551
12/11/10 09:32 PM
12/11/10 09:32 PM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
Thanks all for the advice.
FWIW, I didn't bolt this thing together and I am learning the hard (and most likely expensive) way. Again. LOL!
Think I'm gonna buy a cheapie 12 point box and grind it down and use a propane torch. If that fails, I'll cut it with the grinder.
Re: Help me get this header bolt out! [Re: Ron_M] #877552
12/11/10 09:38 PM
12/11/10 09:38 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
1. spray rust buster on it. 2. go to home depot and buy a torch (they are cheap enough) 3. take your wrench and grind it flatter and take some meat off the sides. 4. heat the bolt...spray let it sit. 5. hit it w/ torch again, let it cool and give it a go. Next time use a Moroso long header bolt w/ a 3/8 head.
Coming soon!!!!
Re: Help me get this header bolt out! [Re: Ron_M] #877553
12/11/10 09:57 PM
12/11/10 09:57 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Try your best to break it loose with a 6 point. A 12 point will come in handy after its broke loose. If the corners are rounding you might use a 6 point like this instead. It uses the sides more than the corners.
Re: Help me get this header bolt out! [Re: Ron_M] #877554
12/12/10 02:49 AM
12/12/10 02:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
A couple of last options,
Make a nice clean cut on the header tube then take it to a muffler shop and have it repaired.
Sawsall / grind the bolt head off.
Leave it on the head, remove the head and unscrew the head from the pipe after it is off.
Re: Help me get this header bolt out! [Re: sthemi] #877555
12/12/10 02:56 AM
12/12/10 02:56 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As hammered as that tube already is I agree cut the tube & have it repaired...
Re: Help me get this header bolt out! [Re: 1_WILD_RT] #877556
12/12/10 09:44 AM
12/12/10 09:44 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Don't cut the bolt unless your taking the heads off.
1,Grind a wrench to fit
2,Cut the header tube
Re: Help me get this header bolt out! [Re: therocks] #877557
12/12/10 10:59 AM
12/12/10 10:59 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Rocky, can you settle a question for me once and for all please as I will be installing headers on a fresh 440 in the near future?
Do any of the exhaust bolts on stock heads go through to the water jacket? I have heard some say yes and some say no.
If the answer is "yes", how would never sieze keep it from leaking?
Scott
1969 Super Bee, 383/4 speed
Re: Help me get this header bolt out! [Re: StukaJU87] #877558
12/12/10 11:40 AM
12/12/10 11:40 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I'm not Rocky, but yes the header bolts enter the water jacket.
