Indy valley plate question #877440
12/11/10 01:33 PM
12/11/10 01:33 PM
Ohio
fiddlestix Offline OP
Ohio
Is there a difference between B and RB valley plates? Mine has a IC49 cast into the bottom of it. I am trying to sell it and have had many questions. Thanks for any help you can give me!!!
Re: Indy valley plate question [Re: fiddlestix] #877441
12/11/10 01:36 PM
12/11/10 01:36 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
yes they are different.
Mopar Performance
Re: Indy valley plate question [Re: moparniac] #877442
12/11/10 01:39 PM
12/11/10 01:39 PM
Ohio
Ohio
How can I tell the difference? It measures about 8 3/8" wide.
Re: Indy valley plate question [Re: fiddlestix] #877443
12/11/10 01:50 PM
12/11/10 01:50 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mine is 8 5/8" wide and I have RB
Mopar Performance
Re: Indy valley plate question [Re: fiddlestix] #877444
12/11/10 02:29 PM
12/11/10 02:29 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Low deck is about 7 3/8" wide typically.
RIP Monte Smith
Re: Indy valley plate question [Re: CompWedgeEngines] #877445
12/11/10 03:05 PM
12/11/10 03:05 PM
Ohio
Ohio
Thanks guys!!!
Re: Indy valley plate question [Re: CompWedgeEngines] #877446
12/11/10 09:46 PM
12/11/10 09:46 PM
NC
440Jim Offline
440Jim  Offline
NC
Yea, I agree.
I just put a tape measure on my low deck one. Measured along the angle at the end rail, it was 7-3/8. If you measure 90 degrees to the side, it will show about 7-1/4.
