Pictures of 70 Cuda Rear Valance Vs 71-74 #877386
12/11/10 11:09 AM
12/11/10 11:09 AM
Berks County, PA
V0B Cuda Offline OP
V0B Cuda  Offline OP
Berks County, PA
This probably has been asked before but I was unable to locate a clear answer. Can someone please post pictures showing the difference between the 70 Cuda rear Valance and 71-74, I know the mounting brackets are not the same. Also am I correct in that 71-74 were the same or is there a difference in those years? Can any another year be mounted on a 70 using the 70 mounting brackets? As always thanks for any help.
Vitamin C-1970 Cuda 440-6 {since 1978}
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: V0B Cuda] #877387
12/11/10 11:53 AM
12/11/10 11:53 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Shorter length cutout on bottom lip edge towards center on each side on 70 verses 71 up.
I'll try and post some pictures
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: V0B Cuda] #877388
12/11/10 09:44 PM
12/11/10 09:44 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
70 on top. No reinforcement.
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: Snoopy] #877389
12/11/10 09:48 PM
12/11/10 09:48 PM
Snoopy Offline
Snoopy  Offline
Bracket comparison.
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: Snoopy] #877390
12/12/10 01:23 AM
12/12/10 01:23 AM
WI
RestoRick Offline
RestoRick  Offline
WI
A couple more pics of a 70...
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: RestoRick] #877391
12/12/10 02:17 AM
12/12/10 02:17 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Date code on an original 1970, not sure if they did this on the later years
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: RestoRick] #877392
12/12/10 03:05 PM
12/12/10 03:05 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That's purdy Rick!
Re: Pictures of 70 Cuda Rear Valance Vs 71-74 [Re: jbc426] #877393
12/12/10 08:54 PM
12/12/10 08:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That's purdy Rick!
I'll second that...It's so reflective you almost can't see the details !!!
