Re: line pressure adjustment
[Re: rebel]
#877223
12/11/10 08:17 PM
12/11/10 08:17 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You won't gain 65 psi with a simple adjustment.
[Re: John_Kunkel]
#877224
12/11/10 09:17 PM
12/11/10 09:17 PM
[Re: rebel]
#877225
12/11/10 09:39 PM
12/11/10 09:39 PM
Posts: 16,925 NC
440Jim
NC
i'm a little over 100 psi & 165 is where i'm aiming for. my problem is, i'm going racing today & want to wind up the pressure before i go racing.
I believe that will require a regulator spring change. I am surprised that trans brake has such a "low" pressure. I would have guessed it would be 120-140 minimum.
[Re: rebel]
#877227
12/12/10 10:22 AM
12/12/10 10:22 AM
Posts: 16,925 NC
440Jim
NC
well for what it's worth. 2 complete turns gained 50 psi. no springs required.
Wow, that is one wicked spring rate. For comparison, my Griner valve body instructions say 8 psi per turn.
Are you sure the original measurement was accurate (rpm, etc)? If it was 135 originally (the range I expected) and two turns gave you 150 that would be closer to the spring Griner uses. But I don't know about the A&A.
[Re: 65dragnet]
#877231
12/13/10 12:55 AM
12/13/10 12:55 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Do yourself a favor , the next time you have your tranny out ,drill and tap the case in-line with the adjuster and put a plug in it. You can adjust the pressure without pan removal.
yep, i was thinking that same thing when i was adjusting it. if i had an 1/8" tap & suitable drill i would have done it right there & then. it's a bit of a no brainer really but then how often would you adjust it?
[Re: rebel]
#877232
12/13/10 01:47 AM
12/13/10 01:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Drilling and tapping would be a smart move on my part, I'll be pulling a 518 apart in the next week or so and I will probably need to adjust it... thanks for the tip guys
