Re: duster front end help
[Re: earthmover]
#877176
12/10/10 11:21 PM
12/10/10 11:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Undo the steering shaft. upper ball joint, upper shock mounts then the 4 K member bolts EDIT forgot the brake lines
[Re: earthmover]
#877178
12/10/10 11:27 PM
12/10/10 11:27 PM
MR_P_BODY
Also just in case you didnt know... turn down the T bars before you pop the upper ball joints EDIT again I normally leave the nuts loose on the ball joints then hit them with the pickle fork to get them to pop free easier then turn down the bars
[Re: earthmover]
#877181
12/11/10 01:22 AM
12/11/10 01:22 AM
MR_P_BODY
Spray ALL the bolts with a good penetration oil... I'm fighting all of them on my Rampage... and I've sprayed them a few times
[Re: Cab_Burge]
#877182
12/11/10 01:45 AM
12/11/10 01:45 AM
Posts: 2,177 ill
dennismopar73
ill
mine pulles off 1 piece, have only bolt at bottom off fenders to losen or i can pull just a fender sep if i want to gary h did hell of job on it
[Re: earthmover]
#877186
12/11/10 11:22 AM
12/11/10 11:22 AM
MR_P_BODY
Oh well. I thought thay there was a guy on here some years back that showed how to do it and make it like a pin on with just a few bolts or pins. Also did the doors I think the name was carl or something ha dit in the tech page but could have been a diff. Board thanks guys mike
I'm setting up my Rampage with a slide on front end and my P-Body has it also... I can have the complete front end off in under 5 minutes(fenders and grille) 2 Dzus fasteners, 2 front pins and 2 bolts... I'll see if I can take some pics today of the Rampage front end... might help you out... both cars are tube chassis cars so the mount on the front slides into the front of the tubing
[Re: earthmover]
#877188
12/11/10 01:13 PM
12/11/10 01:13 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
hey r5p7duster is that a alterkation frontend??? thanks for all the help guys pic would be nice mr.p thanks mike
No, I made the front end myself.
