duster front end help #877175
12/10/10 11:10 PM
12/10/10 11:10 PM
nc
E
earthmover Offline OP
E
nc
well guys im on stand still right now on doing much to the old duster big block build so i wont to do some work on the body..i would like to pull the frontend off in 1 complete part if possible...that way i can get the bay cleaned and do a few odd and ends cause the motor will be on a motor plate.could some one give me some tips on how to get it done if at all possible to take it off complete..i ask cause i never did it and i know that most you racers have if it can be done..just dont wont to take stuff off that dont need to come off thanks mike
also since this car is going to be race only whats the best rear set up ladder bar or four link just to be in the planning..thanks againmike stage for that
Re: duster front end help [Re: earthmover] #877176
12/10/10 11:21 PM
12/10/10 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Undo the steering shaft. upper ball joint, upper
shock mounts then the 4 K member bolts
EDIT
forgot the brake lines
Re: duster front end help [Re: MR_P_BODY] #877177
12/10/10 11:24 PM
12/10/10 11:24 PM
nc
E
E
nc
hay mr.p thanks for that i will have to take that out as well right now i wont to take the fenders,grill and stuff like that off the hood is not a big deal. but never did the fenders and stuff like that and the bumpers i know that can come off by it self..thanks
Re: duster front end help [Re: earthmover] #877178
12/10/10 11:27 PM
12/10/10 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also just in case you didnt know... turn down the T
bars before you pop the upper ball joints
EDIT again
I normally leave the nuts loose on the ball joints
then hit them with the pickle fork to get them to
pop free easier then turn down the bars
Re: duster front end help [Re: MR_P_BODY] #877179
12/11/10 01:03 AM
12/11/10 01:03 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I did mine to make removal easy. The inner fenders are gone, the radiator support is cut out the only thing that sticks out are the stubs and the forward roll bars. The radiator mount is square tubing that bolts in. I don't have the best pics of it, but you should be able to get an idea. Not in chronological either.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: duster front end help [Re: earthmover] #877180
12/11/10 01:15 AM
12/11/10 01:15 AM
Not possible to pull the fenders, front bumper and or hood off as one piece Depending on which year Duster, the fender bolts are along the inner fenderpanels, one or two at the bottom of the fender in front of the door and several behind the grill that bolt into the radiator support, two bolts on each side for the front valance(the sheet metal tying the two fenders together above the front bumper. Pull the front bumper off first and get it out of the way, pull the grill next and disconnect the wiring harnesses and unplug and disconnet the harnesses(two, engine and front end light wire narnesses) as needed and then remove them. Go after the front valence and then the fenders Not a big deal after you have done it once
Re: duster front end help [Re: earthmover] #877181
12/11/10 01:22 AM
12/11/10 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Spray ALL the bolts with a good penetration oil... I'm
fighting all of them on my Rampage... and I've sprayed
them a few times
Re: duster front end help [Re: Cab_Burge] #877182
12/11/10 01:45 AM
12/11/10 01:45 AM
ill
dennismopar73 Offline
ill
mine pulles off 1 piece,
have only bolt at bottom off fenders to losen
or i can pull just a fender sep if i want to
gary h did hell of job on it
Re: duster front end help [Re: dennismopar73] #877183
12/11/10 03:10 AM
12/11/10 03:10 AM
nc
E
E
nc
Oh well. I thought thay there was a guy on here some years back that showed how to do it and make it like a pin on with just a few bolts or pins. Also did the doors I think the name was carl or something ha dit in the tech page but could have been a diff. Board thanks guys mike
Re: duster front end help [Re: earthmover] #877184
12/11/10 03:37 AM
12/11/10 03:37 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
my Cuda has the same kit used on fiberglass front ends installed on my all steel front.the fenders ,upper and lower header panels and grille are all one.
look at any fiberglass maker's catalog
home of the
Sox and Martin Hemi Duster
Re: duster front end help [Re: earthmover] #877185
12/11/10 09:21 AM
12/11/10 09:21 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
you can look thru pics of my Duster..has a ladderbar system and the front end is "Halved"..
the front fenders/grill assemblies slide off as one piece..its still the stock steel fenders
also no inners ...but take a look and see if any of it can be useful to you..
http://smg.photobucket.com/albums/v506/smokinwoody/DUSTER/
Re: duster front end help [Re: earthmover] #877186
12/11/10 11:22 AM
12/11/10 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm setting up my Rampage with a slide on front end
and my P-Body has it also... I can have the complete
front end off in under 5 minutes(fenders and grille)
2 Dzus fasteners, 2 front pins and 2 bolts... I'll
see if I can take some pics today of the Rampage
front end... might help you out... both cars are
tube chassis cars so the mount on the front slides
into the front of the tubing
Re: duster front end help [Re: MR_P_BODY] #877187
12/11/10 12:39 PM
12/11/10 12:39 PM
nc
E
E
nc
hey r5p7duster is that a alterkation frontend???
thanks for all the help guys pic would be nice mr.p thanks mike
Re: duster front end help [Re: earthmover] #877188
12/11/10 01:13 PM
12/11/10 01:13 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
No, I made the front end myself.
SDG Motorsports
Re: duster front end help [Re: DemonDust] #877189
12/11/10 01:24 PM
12/11/10 01:24 PM
nc
E
E
nc
post more please if you got them close up thanks mike
