Looking for radiator #877121
12/10/10 09:04 PM
12/10/10 09:04 PM
SE Wisconsin
49wayfarer Offline OP
SE Wisconsin
I need to find a radiator for my 49 Dodge, with a big block. The car was sectioned and cant' line up fenders without radiator support. Looking at cheapest alternatives. Dimensions I could fit up to 30" wide X 20" tall. Saw some cheap ones at summit and ebay, aluminum ones, don't know if they're OK?
Re: Looking for radiator [Re: 49wayfarer] #877122
12/12/10 05:32 PM
12/12/10 05:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
An aluminum rad will probably the about the only type you will find that will fit in that size limitation. They seem to work well with most dirt track race cars, so I don't see why they wouldn't work on the street.
You also need to make sure you leave enough space for the hot air to exit from under the hood, if the hot air can not get out, air to cool can't get in. This seems to be an area many hot rod builders forget about. Gene
Re: Looking for radiator [Re: poorboy] #877123
12/13/10 06:44 PM
12/13/10 06:44 PM
SE Wisconsin
SE Wisconsin
I found a few aluminum aftermarket ones, but unsure of what ones would be OK, seeing some jegs or Summit, Norther or Be Cool ones are $150-$200, while some like griffin are $550. Going to order one from Jegs for $159, 30 X 19" should be fine.
Re: Looking for radiator [Re: 49wayfarer] #877124
12/13/10 11:57 PM
12/13/10 11:57 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
there is another post going around,,I know you are going to need more than a 19 inch wide radiator to cool a big block..22" min 24" better need 3 core..I had to go to 26" to cool mine,..but 19' I dont think so IMO
Re: Looking for radiator [Re: dynamite] #877125
12/14/10 02:44 PM
12/14/10 02:44 PM
SE Wisconsin
SE Wisconsin
It is a crossflow, 30" wide X 19" tall, haven't decided on one yet.
Re: Looking for radiator [Re: 49wayfarer] #877126
12/14/10 03:19 PM
12/14/10 03:19 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I think if you have enough airflow that 30x19 will work just fine with an electric fan.
'Nice talking to you the other day bud!
