73 Satellite / Roadrunner BB or small block K-frame #876208
12/10/10 02:33 AM
12/10/10 02:33 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
How can I ID a 73 Satellite/ Roadrunner Big block K frame. I have one Satellite that came with a 318 and was an all original car so I know that one is a small block K-frame but my parts car which is also a 73 Satellite Has a 440 in it but I think it was a factory small block car. Is there an easy way to tell a big block K-Frame from a small block K-frame. Pictures would help a lot thanks for the help.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876209
12/10/10 10:46 AM
12/10/10 10:46 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I am not sure about these cars but I was recently told the k-members where the same. Don't know how true that is.
I have a 73 that had a 440 in it but it originally had a 318 in it. I remember my dad telling me that he put a kmember out of a BB cordoba in it, but like I said, I had a guy tell me that didn't make sense because they should have been the same.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: RonP] #876210
12/10/10 12:03 PM
12/10/10 12:03 PM
Boise Idaho
Boise Idaho
I decoded the VIN and this car was a factory small block car the motor seems to fit nicely even with headers. Without knowing what too look for I can't tell any difference between the K-frames. I did notice that the car with the 440 in it does not have an oil dipstick and I can't see behind the the motor mount to be able to tell why. Did all 440's have provisions for a dipstick on the driver's side of the block ? I hope so as I plan to use this motor in my car.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876211
12/10/10 01:18 PM
12/10/10 01:18 PM
IMGTX Offline
IMGTX  Offline
All 440's have a dip stick provision on the drivers side.
There is a difference in the K-frames in 73 and later BB vs. SB engines. Sorry I don't have pictures.
One way to tell a BB car is the passenger side inner fender is different. The small blocks had a full inner fender and a small access hole for the UCA adjustment bolts about 6" across with a metal plate over it. The BB cars had much of the inner fender removed from front of the UCA area to the firewall and from about 1/2 way down to the bottom. It was covered with a large rubber mat.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876212
12/10/10 01:27 PM
12/10/10 01:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I yanked the 360 out of my 74 RR and dropped in a 440 using Cordoba mounts and a C-body oil pan. It ran like that for 10 years. Fast forward 5 years and the guys on Moparts tell me I did it wrong.
- Stu Harmon
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876213
12/10/10 01:42 PM
12/10/10 01:42 PM
AndyF Offline
AndyF  Offline
Schumacher has conversion motor mounts so you can put a big block into a small block K frame. I think they might also have pictures of the different K-frames on their website or in their book.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: AndyF] #876214
12/10/10 02:05 PM
12/10/10 02:05 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
the k frames are physically the same pieces, the difference is where the motor mount ears are welded on. I used to have pictures saved a couple of computers ago. This topic seems to come up every so often, and theres always a debate over if there was a difference or not. Not to say you can't put a big block onto a small block k frame. However, when I tried it in high school, I had some alignment issues....
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876215
12/10/10 03:04 PM
12/10/10 03:04 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I dropped a mock up 440 block on small block K way back when. Looking at it, everything looked fine. My girlfriend (at the time) pointed out that the engine was crooked, and she was right. Not alot but enough to cause issues. My fix was to lop off the drives side mount and move it back about an inch to correct the problem. My understanding is that the pass side might is in a different spot too.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: feets] #876216
12/10/10 03:12 PM
12/10/10 03:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Another one of those things that books and computers say can't be done. But if you don't know any better and just go ahead and do it will work fine.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: MoparforLife] #876217
12/10/10 03:28 PM
12/10/10 03:28 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
This car was a 73 satellite with a 400.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876218
12/10/10 05:44 PM
12/10/10 05:44 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Another easy way if the car is still fairly intact is see of the passenger-side fender is solid, or has the rubber mat covering an opening in like in the picture above. Small block cars did not have the open fenderwell.
Another way... do you have the VIN?
The Blue Goose
My instagram: Bossride
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: BossRide] #876219
12/10/10 06:27 PM
12/10/10 06:27 PM
Boise Idaho
Boise Idaho
I know from the vin's and the P-side inner fender that both cars are small block cars I just don't know it the parts car with the big block in it has the factory K-frame or it was swapped for a big block K-frame.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: BossRide] #876220
12/10/10 06:29 PM
12/10/10 06:29 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I drop a 340 into my 73 that had a 400, I had no problems, except getting the right mounts!
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: MoparforLife] #876221
12/10/10 06:41 PM
12/10/10 06:41 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Sure you can do it but the trans won't bolt up in the crossmember that why there IS a BB and SB K-member. I tried 20 year ago and couldn't get the mounts to fall in and ended up plasma cutting the mounts off and welding BB ones on....Everything lined up fine then. I couldn't imagine getting one in and driving it with the tail shaft of the trans pointing towards shock...
Oh and the easy way to tell whether the K-member is a BB or SB is that BB are straight across and the SB mounts are staggered in appearance when looking sideway at the K-member....
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: QuickBpBp] #876222
12/10/10 09:25 PM
12/10/10 09:25 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
So based off that this is a BB k-member in the pic?
I hope to have this car back together for my son next summer and it hasn't had a motor in it for 20 years.
Like I said, this is an original SB car and I remember we had a BB in it and I disticntly remember helping my dad change the k-member with the motor in. I guess things weren't lined up right and someone told him to get a kmember from a cordoba and we did.
I have no idea what motor mounts to use or what they look like.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: RonP] #876223
12/10/10 09:27 PM
12/10/10 09:27 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
another
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: RonP] #876224
12/10/10 09:34 PM
12/10/10 09:34 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Yes it is a Big block K-member from what I can see in the pics and yes originallly a small block car. If you are planning on running headers you will need to trim some of the inner engine pan on the RH for tube clearance atleast I had to with my hooker super comps....
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: QuickBpBp] #876225
12/10/10 09:54 PM
12/10/10 09:54 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Yeah, i want to run headers, but I heard it will be a mess. What is funny is the guy that did the body work and paint fixed that exact spot as my dad had it all kinds of cut up holes punched and so forth. Bummer.
Where in that pic should I cut it?
Thanks a bunch and didn't mean to hijack this thread.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: RonP] #876226
12/10/10 10:46 PM
12/10/10 10:46 PM
Boise Idaho
Boise Idaho
I already cut and replaced the section on the RH lower inner fender to clear the headers So I don't think I'll have a problem with that.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876227
12/11/10 04:54 PM
12/11/10 04:54 PM
Sonora. Mexico
charger'72mod Offline
Sonora. Mexico
I think that the K member are the same, the difference is on the motor mounts, attached is a picture of my 400 bb charger k member with a 360 on it, the difference, only the mounts
