Do electric vacuum pumps for power brakes work? #876111
12/09/10 11:40 PM
12/09/10 11:40 PM
Louisiana
duckblind Offline OP
Louisiana
I have problems with the power brakes on my 68 charger. I think this is due to the cam I have as the brakes work find when the first time I apply them from a cruising speed but the vacuum doesn't seem to keep up if I am in traffic or for any multiple brake pumping. I see they make electric vacuum pumps for such a problem. Do they really work?
Re: Do electric vacuum pumps for power brakes work? [Re: duckblind] #876112
12/09/10 11:52 PM
12/09/10 11:52 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Bunch of OEMs are still using them on applications with little vacuum like Turbo cars or 5cyls (or both, lookin at you Volvo).
Re: Do electric vacuum pumps for power brakes work? [Re: RokketRide] #876113
12/10/10 12:15 AM
12/10/10 12:15 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
We have one plumbed in on the 72 charger. Got some one way in line valves from a Honda (I think) so I could have both it and the motor vacuum pulling on the booster.
Haven't got it street legal yet but driving around pit roads can be a lot of stop and go and so far so good.
Re: Do electric vacuum pumps for power brakes work? [Re: WILD BILL] #876114
12/10/10 01:21 AM
12/10/10 01:21 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
Diesels either must use a hydroboost or a vacuum pump, one or the other
Re: Do electric vacuum pumps for power brakes work? [Re: Yancy Derringer] #876115
12/10/10 10:02 AM
12/10/10 10:02 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Yes they work. I pulled a couple from Cadillacs at our local pull a part and mounted one behind the headlight bucket on the drivers side. Works just fine. Its noisey until I fire up the engine then I cant hear it. I needed to take my cordless drill to remove them as you have to drill out the mounting plates. Take it all if this is the way you go. The mounting plates are specific and include rubber mounts to cut down on the noise.
Re: Do electric vacuum pumps for power brakes work? [Re: Cudajon] #876116
12/10/10 12:40 PM
12/10/10 12:40 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
I have used new ones from summit if you want to go that route. Yes they work. Yes they are noisey until they pump up. Billet one is $$$ but looks good. I think they have a lower price unit also.
Re: Do electric vacuum pumps for power brakes work? [Re: duckblind] #876117
12/10/10 01:39 PM
12/10/10 01:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I ran a 263 @ .050 on my GTX on the street I just set my idle to 1150 in gear and it was fine.
Still run the power with a 272 @ .050 cam got the isle at 1250 in gear. stops me from 130. fine in te pits and return roads.
but going to standard brakes next spring
Re: Do electric vacuum pumps for power brakes work? [Re: Dodgem] #876118
12/10/10 02:06 PM
12/10/10 02:06 PM
Louisiana
Louisiana
I was planning on going with standard brakes but a friend of mine is trying to talk me into the vacuum pump. It has been many years since I have driven something with manual brakes but I don't remember them being all that hard to push. I suppose I could try getting one out of an old cadilac or a different vehicle. I saw them at summit for around $300 and don't really want a $300 experiment to find out I don't like the vacuum pump, that is why I may try the cadilac route first.
Re: Do electric vacuum pumps for power brakes work? [Re: duckblind] #876119
12/10/10 02:13 PM
12/10/10 02:13 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
You can always dial in your pedal feel on a manual setup by trying a master cylinder with a different piston diameter. Dr Diff sells aluminum MC in like 4 different sizes. Shaves a couple pounds and no rust as a bonus.
Re: Do electric vacuum pumps for power brakes work? [Re: duckblind] #876120
12/10/10 02:36 PM
12/10/10 02:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
With enough intial timing, you should have enough vacuum for brakes.
Re: Do electric vacuum pumps for power brakes work? [Re: Challenger 1] #876121
12/10/10 03:03 PM
12/10/10 03:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Probably why mine PB always worked 38 to 40 degree's all in by 1200?
Re: Do electric vacuum pumps for power brakes work? [Re: Dodgem] #876122
12/10/10 06:45 PM
12/10/10 06:45 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I paid $20 bucks for the two I got, including all the electrical connectors, etc. Even if the diapram is blown you can make a diaphram outta an old inner tube to fix it. It will not effect braking if it blows they'll just go back to being hard to push.
Re: Do electric vacuum pumps for power brakes work? [Re: Cudajon] #876123
12/11/10 05:02 AM
12/11/10 05:02 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have mine off of a 78 Cadillac DeVille. I got three from a boneyard and pieced one together to make it work. Still going after 8 years. I have it mounted under my battery tray with a one liter vacuum canister in the wheel well. Is a bit noisy on startup until the engine kicks over....and I have but an Isky 280/480 MegaCam in my Charger.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
