Re: 69 1/2 lift off hood air cleaner????
[Re: AB&E]
#875805
12/09/10 11:02 PM
12/09/10 11:02 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
thanks its a start. have you dealt with this company personally??
He's a Moparts member.
[Re: AB&E]
#875810
12/10/10 05:00 PM
12/10/10 05:00 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
It is NOS, used original, Ben's, fiberglass, or an old bath towel. Actually, I think the bases are covered as far as sources and am not aware of any other steel repops. Not what you were hoping to hear but I think that's it.
dstryr, since 1986.
[Re: dstryr]
#875812
12/10/10 11:52 PM
12/10/10 11:52 PM
Posts: 6,301 colorado
a12superbee
colorado
There seems to be, believe it or not, quite a few halves of the bases, both the inside and the outside. The halves aren't worth half of what a good part is so there's some potential to save yourself some $. Run a wanted ad and see whats out there. That guy in London probably has some.
Opps edit I should say there WERE both halves floating around.
I can't afford this.
mark
