SB PUSHRODS #875594
12/09/10 03:15 PM
12/09/10 03:15 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Besides Smith Brothers and Manton,is there any other companies I can get pushrods from??
I need 5/16 but as thick of a wall as possible.
Re: SB PUSHRODS [Re: MIKES_DUSTER] #875595
12/09/10 03:24 PM
12/09/10 03:24 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i believe comp sells various lengths of pushrods
Re: SB PUSHRODS [Re: DJVCuda] #875596
12/09/10 03:27 PM
12/09/10 03:27 PM
South Lyon, Michigan
6bblRoadrunner Offline
Re: SB PUSHRODS [Re: 6bblRoadrunner] #875597
12/09/10 04:38 PM
12/09/10 04:38 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Whats goin on? I thought yours was running? I tore mine back down to change to a different head combo. Doya know how long ya need? I have a set that I might not be able to use. Ill sell em to ya. They are MANTON, PM me with the length, and Ill see what I can do. They had 600psi ish of spring on them so they should work for ya, and were on my engine for maybee100-150 miles.
Kasey
Re: SB PUSHRODS [Re: Moparnut426] #875598
12/09/10 05:18 PM
12/09/10 05:18 PM
I really dont know what kind and how thick my pushrods are so to be safe I need to change them out.
Re: SB PUSHRODS [Re: MIKES_DUSTER] #875599
12/09/10 05:21 PM
12/09/10 05:21 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Why rule out smith bros or manton?
I have smith bros, had them in 2 days, good for over #700 lbs in two day 5/16x.116 but its overkill for me but ive seen in some testing at least on the thick 5/16 were good for 300 more rpm then a .080 5/16 due to deflection.
I do have some sets of cut to fit from the indybrocks I buy but dont use, they seem to be .060 if they would work for you they are FREE...just send me an addy.
Re: SB PUSHRODS [Re: quick77rt ] #875600
12/09/10 07:06 PM
12/09/10 07:06 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I just ordered another set of Smith Bros the other day, they were literally on my doorstep in less than 24 hours! and they look pretty too!
Re: SB PUSHRODS [Re: Baxter61] #875601
12/09/10 07:19 PM
12/09/10 07:19 PM
Lehigh Acres, Florida
rickstershemi Offline
Smith Brothers in my 408 & yes they are purdy
Rickster
Re: SB PUSHRODS [Re: rickstershemi] #875602
12/10/10 12:37 PM
12/10/10 12:37 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I also say spend the extra coin on Smith Bros. Nothing but bad luck with Comp here.
Re: SB PUSHRODS [Re: MIKES_DUSTER] #875603
12/10/10 02:28 PM
12/10/10 02:28 PM
408Dust Offline
408Dust  Offline
What kind of cam are you using? Flat or Roller? What kind of spring pressure?
Re: SB PUSHRODS [Re: 408Dust] #875604
12/10/10 02:35 PM
12/10/10 02:35 PM
Im running a solid roller cam. Not sure of the spring pressures. Its not a big cam,.556/.556 lift.
Re: SB PUSHRODS [Re: MIKES_DUSTER] #875605
12/10/10 02:57 PM
12/10/10 02:57 PM
408Dust Offline
408Dust  Offline
Bet 5/16 .080 wall pushrod is fine for your application, if your not using a lot of seat pressure and turning a bunch of RPM spend your money on something else.
