Piston pins selection #875519
12/09/10 12:05 PM
12/09/10 12:05 PM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
I need some help picking out the right piston pins for my pistons. I want the lightest ones possible that won’t cause problems. The pistons weight 585 grams, it has a 4.75 stroke. They are the typical ross piston pin 2.93 long .990 diameter.
I have looked at some tool steel, they are .150 thick and weigh 144 grams, I would just like something lighter if it would work.
Joe
Without Data, you’re just another guy with an opinion.
Re: Piston pins selection [Re: sr4440] #875520
12/09/10 12:20 PM
12/09/10 12:20 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
did you consider any coatings on them ?
home of the
Sox and Martin Hemi Duster
Re: Piston pins selection [Re: HEMIFRED] #875521
12/09/10 12:29 PM
12/09/10 12:29 PM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
I planned on coating them, i was more worried about flex and failure if i went to light.
Joe
Re: Piston pins selection [Re: sr4440] #875522
12/09/10 01:00 PM
12/09/10 01:00 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Use coated titanium.
