HP difference from a 59 degree to a 48 degree #875476
12/09/10 11:26 AM
12/09/10 11:26 AM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I was just wondering what kinda difference in power a person might see in a small cubic inch W2 engine from a 59 degree set-up compared to a 48 degree set-up ? I know the 48 degree would rpm better, but how much better and how much power, roughly ?
J.C. Childress (434) 665-9541
Re: HP difference from a 59 degree to a 48 degree [Re: JC Childress] #875477
12/09/10 11:57 AM
12/09/10 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If the valves opened the exact same I dont think
you could really measure it... the lifter is side
loaded a more in the 59 vs the 48... I am talking
the same head on both.... JMO
Re: HP difference from a 59 degree to a 48 degree [Re: MR_P_BODY] #875478
12/09/10 12:02 PM
12/09/10 12:02 PM
Big Island ,VA
Big Island ,VA
I'm speaking of a 59 degree head on a 59 degree block versus a 48 degree head on a 48 degree block.
Re: HP difference from a 59 degree to a 48 degree [Re: JC Childress] #875479
12/09/10 12:08 PM
12/09/10 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Now you talking flow numbers... on my W-9 head
which is a 48* it flows more than the (we will say
a W-5) so your not looking at apple to apples....
if you put a W-8 on a 59 it will make enough power
to bust the stock 59* block
Re: HP difference from a 59 degree to a 48 degree [Re: JC Childress] #875480
12/09/10 12:13 PM
12/09/10 12:13 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
No numbers but would guess significantly more hp with the 48 setup.
the 48 degree's broader rpm capabilities enable it to accomodate more cfm.
Re: HP difference from a 59 degree to a 48 degree [Re: theclutcher] #875481
12/09/10 12:15 PM
12/09/10 12:15 PM
Big Island ,VA
Big Island ,VA
I'm talking about W2 heads....48 and 59 degree.
Re: HP difference from a 59 degree to a 48 degree [Re: JC Childress] #875482
12/09/10 12:28 PM
12/09/10 12:28 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Had a set of W2 here that would support 8500+.
had valvetrain issues at lower rpm than that with 59 degree stuff.
Hp would be the same up to the point where valvetrain issues arise all else equal imo.
After seeing the 48 degree stuff the 59 is just ugly.
To choose between the two, 48 w2 vs 59 w2, 48 will make more power at higher rpm imo..
How high you want to spin it and how long?
Re: HP difference from a 59 degree to a 48 degree [Re: theclutcher] #875483
12/09/10 12:53 PM
12/09/10 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My W-2 on a 59* block I was turning it 8200 on each
pass... gotta have a good valve train... this was a
roller... I was running 9.56 with it
Re: HP difference from a 59 degree to a 48 degree [Re: MR_P_BODY] #875484
12/09/10 01:13 PM
12/09/10 01:13 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Could you have utilized more rpm had the valve train been capable?
I didnt have the ultimate set up for sure, good parts but, after seeing the potential reliability of the 48 degree stuff, decided not to chase 59 degree further.
OT successful up north?
Re: HP difference from a 59 degree to a 48 degree [Re: theclutcher] #875485
12/09/10 02:08 PM
12/09/10 02:08 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Good luck finding 48* W2's. MP is always out of them & I kind of doubt they will make anymore but never know. Will have to find some in private ownership.
I dynoed a 394" 48* W2 with 47 CC chamber earlier this year for a dirt modified, made good power (630's?) for the mild flat tappet, I was very pleased with it. That thing with a good roller & little more of a "drag" setup could have made some real good power #'s for a W2. Those are really nice heads I just wish they were more readily available.
Forgot I also dynoed a 365 with the 48* open chamber verison unported @ 10.5:1 with a flat tappet as well this year. Again made good power #s for what it was, 570's unported heads? Stock 360 block & crank.
Re: HP difference from a 59 degree to a 48 degree [Re: RyanJ] #875486
12/09/10 02:30 PM
12/09/10 02:30 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I know nothing about small blocks but what is the difference on the heads between the 2 different degree heads? pushrod location is the only difference i can think of
Re: HP difference from a 59 degree to a 48 degree [Re: RyanJ] #875487
12/09/10 02:39 PM
12/09/10 02:39 PM
Big Island ,VA
Big Island ,VA
I'm speaking more along the lines of a 285ci engine. A high winding,modified type engine.
I know of a 321ci W2 headed,all 48 degree engine that makes over 700 HP ! Of course no expense has been spared on it.
If they may not make anymore 48 degree heads, whats the fix for the valvetrain issues in a high winding,small cubic inch sb Mopar ? With W2 heads I mean. Also, whats the best cast intake for W2 heads ? Also, could you use 48 degree heads on a 59 degree R3 block, and if so, to what advantage ?
Re: HP difference from a 59 degree to a 48 degree [Re: sixpackgut] #875488
12/09/10 06:19 PM
12/09/10 06:19 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The 48s are 15 degree valve angle.
Re: HP difference from a 59 degree to a 48 degree [Re: JC Childress] #875489
12/09/10 07:24 PM
12/09/10 07:24 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
At the RPMs you'll need to be at to make big power with 285" engine,
the 48º lifter angle will have a definite advantage.
Kent Ritter has/had my last set of 48º/15º 47cc W-2 heads. (P5007708AB)
Re: HP difference from a 59 degree to a 48 degree [Re: S/ST 3040] #875490
12/09/10 11:36 PM
12/09/10 11:36 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
That would be sweet to hear.
10,500 rpms of mighty mouse mopar.
