Fly Cutting Piston Reliefs #875278
12/08/10 10:57 PM
12/08/10 10:57 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I am debating whether to fly cut the reliefs in my TRW 2355 6pak pistons to free up some more ptv clearance. The larger intake valve on the Eddy head is my main concern. Right now I have .120" clearance and I would like to shave my heads for more compression.
If I were to have the valve reliefs opened up would it be as simple as enlarging what is currently there or do the Eddy valves come at the piston at a different angle than the valves in the stock heads? I am just wondering how complicated this would be to do right if I do decide to pull the pistons?
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: Fly Cutting Piston Reliefs [Re: tywebb2] #875279
12/08/10 11:12 PM
12/08/10 11:12 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
dont have a pics of the tool but what you can do is raise the piston to TDC and put a valve stem with a fine point (machined center obviously)(the tool) in the valve guide in the head and "knock" it into the piston to give a valve center location and give piston to machine shop... or use an in head piston cutter
maybe a pro here will give ya a better advice or technique...
Mopar Performance
Re: Fly Cutting Piston Reliefs [Re: tywebb2] #875280
12/09/10 01:08 AM
12/09/10 01:08 AM
Delray beach, Florida
P
Performance Only Offline
P
edelbrock heads use the same valve angle as factory heads. just clay the piston, roll the motor over to make an impression and hand it to your machinist. if they just need to be deeper then don't bother with all tht, but if they need to be enlarged and deeper, use the clay, it's idiot proof.
machine shop owner and engine builder
Re: Fly Cutting Piston Reliefs [Re: Performance Only] #875281
12/09/10 12:13 PM
12/09/10 12:13 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
As i said on the other thread, i used a crane R280 roller with those pistons, with shims and 76cc edelbrock heads and 1.5 rockers to 7000 rpm.
I clayed them first on every cylinder and there was adequate clearance but not enough to advance the cam. My pistons measure .018 below deck.
What cam are you looking to use and has the block been decked.
Hope this helps
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Fly Cutting Piston Reliefs [Re: tywebb2] #875282
12/09/10 01:22 PM
12/09/10 01:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
mill .040 off the heads and be happy .080 is lotso clearence. especially for a 6000 rpm engine.
6000 ish is good shift point with a 509 cam.
Re: Fly Cutting Piston Reliefs [Re: Dodgem] #875283
12/09/10 08:42 PM
12/09/10 08:42 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Alright....I'll give it a try. My plan is to pull the heads and then bolt them down without the head gasket to check ptv with clay on top of the pistons. That way I can check to see if the intake valve is even sitting down in the valve notch in the piston or not.
'72 440 Cuda
Re: Fly Cutting Piston Reliefs [Re: moparniac] #875284
12/19/10 09:17 AM
12/19/10 09:17 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
pic
Mopar Performance
Re: Fly Cutting Piston Reliefs [Re: moparniac] #875285
12/19/10 10:56 AM
12/19/10 10:56 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Why not use a transfer punch? That's what I use.
Re: Fly Cutting Piston Reliefs [Re: tywebb2] #875286
12/19/10 03:58 PM
12/19/10 03:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The clay method is excellent because the valve opens in 2 planes, and the head will plow the clay aside to follow the actual motion path:
1. deeper as it lifts
2. across the dome due to the stem angle
In a wedge, the "across" motion is small, generally enough that the usual safety margin (OD + .100" etc. includes it.
In a hemi, the scrub across is quite significant, and simply adding depth leaves you with less safety toward the dome center than you think you have.
Boffin Emeritus
Re: Fly Cutting Piston Reliefs [Re: polyspheric] #875287
12/19/10 04:05 PM
12/19/10 04:05 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
A old valve ground to a point and punch will be the best. Tell the machine shop to use a cutter that measures .100 larger than the valve your cutting.
Re: Fly Cutting Piston Reliefs [Re: Bob_Coomer] #875288
12/19/10 06:00 PM
12/19/10 06:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, nobody uses the old "tool bit brazed to a valve" homemade in place cutter anymore? A good way to be sure the cutter is in the correct position is to do the cutting from the actual valve guide that will be above the piston.
Re: Fly Cutting Piston Reliefs [Re: John_Kunkel] #875289
12/19/10 06:15 PM
12/19/10 06:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've done that years ago, now days I have a mill
Re: Fly Cutting Piston Reliefs [Re: tywebb2] #875290
12/19/10 06:42 PM
12/19/10 06:42 PM
Az
Crizila Offline
Crizila  Offline
Az
This is a pic of a piston in my 408 that I cut the valve reliefs in using a cutter I rented from Hughes engines. Basically it was a section of head with valves in it that had carbide cutters welded to the valve faces. Worked great. You might want to check with them to see if they have something that will work with your application.
Fastest 300
Re: Fly Cutting Piston Reliefs [Re: John_Kunkel] #875291
12/19/10 07:30 PM
12/19/10 07:30 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Id like to see a pic of that "tool" John. It was just more simple for me to use a old valve drop it down the guide and punch the piston at TDC, seems that this way would be just as accurate, and cheap to make also.
Re: Fly Cutting Piston Reliefs [Re: Bob_Coomer] #875292
12/19/10 09:00 PM
12/19/10 09:00 PM
Az
Crizila Offline
Crizila  Offline
Az
I'll look for it Bob.
Fastest 300
Re: Fly Cutting Piston Reliefs [Re: Crizila] #875293
12/19/10 09:16 PM
12/19/10 09:16 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I used in head cutters from lindy tools....
Mopar Performance
