small block roller rockers???????? #873949
12/07/10 09:26 PM
12/07/10 09:26 PM
ohio
all spooled up Offline OP
ohio
whats a good brand to run hughes/ comp cams/ i know harland sharps are good but i dont know if i should spend 700.00. these are for rhs indy x heads and i will be running a roller cam.
Re: small block roller rockers???????? [Re: all spooled up] #873950
12/07/10 09:50 PM
12/07/10 09:50 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Harland Sharp !! spend a little more $$$ for the best !
Switched to the dark side...
Re: small block roller rockers???????? [Re: JSR1485] #873951
12/07/10 09:54 PM
12/07/10 09:54 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I dont know if HS is the best. But they are very good.
I would think T&D or Jesel is the best.
But now you are talking about spending ALOT of money.
I had good luck with crane gold rockers, i just had to change the adjuster screws in them.
I ran those on my W2 heads.
Re: small block roller rockers???????? [Re: HEMIDARTS] #873952
12/07/10 09:59 PM
12/07/10 09:59 PM
ohio
ohio
i have a set of crane gold roller rockers i think there from 2001
Re: small block roller rockers???????? [Re: all spooled up] #873953
12/07/10 10:21 PM
12/07/10 10:21 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
the only flaws i saw with them was the adjuster screws.
It is money ahead to pay Smith Bro's $75.00 and get very nice adjusters!!
Re: small block roller rockers???????? [Re: all spooled up] #873954
12/07/10 11:46 PM
12/07/10 11:46 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
And you're spending how much on this ?
Harland Sharp..........at a minimum.
You can spend less and wonder if it is good enough I suppose.
For what you get in quality , extra features and piece of mind .......... they are a bargain.
Re: small block roller rockers???????? [Re: tubtar] #873955
12/08/10 08:00 AM
12/08/10 08:00 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have a new set of comps in the forsale sec.
Re: small block roller rockers???????? [Re: tubtar] #873956
12/08/10 11:29 AM
12/08/10 11:29 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I agree. This is no place to try to save money. Actually, it Jesel or T+D for me now. HS are a pretty good alternative.
Re: small block roller rockers???????? [Re: all spooled up] #873957
12/08/10 12:02 PM
12/08/10 12:02 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Are they the LA or Magnum version?
I'm one of the odd people who went with the magnum version and I used the hughes magnum shaft roller rockers. Awesome pieces.
I can't see why the same hughes roller rockers for the LA shafts would be any worse...
IMO, I would definitley give the hughes rockers a look.
Not taking anything away from the harlands, but I think the hughes are just a better rocker. I dont know that to be a fact, but it's definitely my opinion and I do own both.
Re: small block roller rockers???????? [Re: POS Dakota] #873958
12/08/10 12:43 PM
12/08/10 12:43 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
If they are a shaft style rocker set up the difference in price between T&D and Harland Sharp isn't $100.00 So why not have the best. Call T&D and ask them, there are great to work with. (775)884-2292.
Re: small block roller rockers???????? [Re: POS Dakota] #873959
12/08/10 12:43 PM
12/08/10 12:43 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Ok let the bashing begin. I have tried a lot of rockers with my Eddie headded 422. I was having a problem with clearance with my 1.55 springs. The best and most material I found on a roller rocker was C.A.T. I had to clearance these rockers for fit and they still had a lot of material for strength. I know how most people feel about forign parts but they have worked for me when others have not.
6.50 @105.26
Re: small block roller rockers???????? [Re: Kindafast] #873960
12/08/10 02:14 PM
12/08/10 02:14 PM
ohio
ohio
la shaft not magnum i might just stay with my w2 set up.....
Re: small block roller rockers???????? [Re: Biginchmopar] #873961
12/08/10 07:05 PM
12/08/10 07:05 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I just got a new set of HS this year got them from Mike at HS the total cost with shipping was 647.00 I had spoke with T&D at the PRI show at the same time they wanted over 900.00 for the same thing and the HS will clear a larger od spring.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: small block roller rockers???????? [Re: dusturbd340W5] #873962
12/08/10 07:58 PM
12/08/10 07:58 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Anybody used the old comp magnums (not pro magnums)?
I called RAS the other day, and they can setup shaft mounted rockers that are bushed ductile iron up to a 1.6 ratio for $255 if you send in your old stuff. These are adjustable and non roller tip
Re: small block roller rockers???????? [Re: mshred] #873963
12/08/10 11:13 PM
12/08/10 11:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I ground the pi$$ out of my Hughes rocker arms to clear my Comp 930 springs. They've been on the engine for a year and half with no issues.
Re: small block roller rockers???????? [Re: justinp61] #873964
12/08/10 11:24 PM
12/08/10 11:24 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I have a good used set of sharps that have been cut to clear the 099? comp spring, they were used with a mild roller .623 1.6 ratio, never had an issue with adjusters. I don't know why I have not created anything in the for sale section, but I really should. My Sharps were always failsafe.
Re: small block roller rockers???????? [Re: wheelsup68dart] #873965
12/09/10 12:55 PM
12/09/10 12:55 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Here you go.
Problem solved.
I have a 1.5 set , but I haven't decided if I will use them again or not, so they haven't made it to the for sale section yet either.
I would not have a problem running used H.S. rockers for a solid street build.
They are also re-buildable.........something I don't think you can pull off with bushed rockers.
