small block roller rockers????????
#873949
12/07/10 09:26 PM
12/07/10 09:26 PM
Posts: 1,049 ohio
all spooled up
ohio
whats a good brand to run hughes/ comp cams/ i know harland sharps are good but i dont know if i should spend 700.00. these are for rhs indy x heads and i will be running a roller cam.
Re: small block roller rockers????????
[Re: all spooled up]
#873954
12/07/10 11:46 PM
12/07/10 11:46 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
And you're spending how much on this ? Harland Sharp..........at a minimum. You can spend less and wonder if it is good enough I suppose. For what you get in quality , extra features and piece of mind .......... they are a bargain.
[Re: tubtar]
#873956
12/08/10 11:29 AM
12/08/10 11:29 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I agree. This is no place to try to save money. Actually, it Jesel or T+D for me now. HS are a pretty good alternative.
#873957
12/08/10 12:02 PM
12/08/10 12:02 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Are they the LA or Magnum version?
I'm one of the odd people who went with the magnum version and I used the hughes magnum shaft roller rockers. Awesome pieces.
I can't see why the same hughes roller rockers for the LA shafts would be any worse...
IMO, I would definitley give the hughes rockers a look.
Not taking anything away from the harlands, but I think the hughes are just a better rocker. I dont know that to be a fact, but it's definitely my opinion and I do own both.
[Re: wheelsup68dart]
#873965
12/09/10 12:55 PM
12/09/10 12:55 PM
tubtar
St. Paul , Mn.
I have a good used set of sharps that have been cut to clear the 099? comp spring, they were used with a mild roller .623 1.6 ratio, never had an issue with adjusters. I don't know why I have not created anything in the for sale section, but I really should. My Sharps were always failsafe.
Here you go. Problem solved. I have a 1.5 set , but I haven't decided if I will use them again or not, so they haven't made it to the for sale section yet either. I would not have a problem running used H.S. rockers for a solid street build. They are also re-buildable.........something I don't think you can pull off with bushed rockers.
