Re: Nitrous Plug, RB Edelbrock RPM heads
[Re: gsmopar]
#873586
12/07/10 05:54 PM
12/07/10 05:54 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
R5671A-8 which should be the stock number 4554. that's a non-projected tip with a 5/8 hex,gasket seat with a .750 reach.
[Re: gsmopar]
#873587
12/07/10 05:59 PM
12/07/10 05:59 PM
Posts: 1,200 UK
602heavy
UK
ps: no more than a 150 shot, probably sticking to a 125 this weekend.
Steer away from the projected type plugs , these will have a 'p' in the part # , i use BCR8ES on alu heads , iron heads will be a different part number , maybe get a couple of sets (BCR7ES/BCR8ES) , 125/150 hit should be fine using the -7s , not sure if part numbers are different in United States , had issues with this before.
[Re: 602heavy]
#873588
12/07/10 06:10 PM
12/07/10 06:10 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
R5671A-9 8 heat range is a little hot for NOS IMO.
Leon
[Re: Leon441]
#873589
12/07/10 06:19 PM
12/07/10 06:19 PM
Posts: 1,200 UK
602heavy
UK
Leon
Just a little concerned the OP will keep taking fuel away if using the -9s on that small a shot.
[Re: kdhull]
#873591
12/08/10 12:30 PM
12/08/10 12:30 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
perhaps this might help.
Thanks!!!!!!
