Nitrous Plug, RB Edelbrock RPM heads #873583
12/07/10 02:27 PM
12/07/10 02:27 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
What plug do you guys recommend? I was running Autolite 3923's.
Thanks,
Greg
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: gsmopar] #873584
12/07/10 04:11 PM
12/07/10 04:11 PM
UK
602heavy Offline
602heavy  Offline
UK
Sometimes it's not good being the first to reply on these nitrous threads. ...................................i prefer NGKs for the simple reason their more forgiving , nip a strap on an autolite & you've possibly damaged a piston , the NGKs are a bit like a fuse , genarally speaking you will loose a ground strap before a piston.
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: 602heavy] #873585
12/07/10 04:47 PM
12/07/10 04:47 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Do you have a PN? I'm having a hard time deciphering the project tip, heat range, etc... on the PN's. I've found a couple helpful sites (NGK's being one of them), but ended up ordering the wrong plug.
Thanks!
ps: no more than a 150 shot, probably sticking to a 125 this weekend.
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: gsmopar] #873586
12/07/10 05:54 PM
12/07/10 05:54 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
R5671A-8 which should be the stock number 4554. that's a non-projected tip with a 5/8 hex,gasket seat with a .750 reach.
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: gsmopar] #873587
12/07/10 05:59 PM
12/07/10 05:59 PM
UK
602heavy Offline
602heavy  Offline
UK
Steer away from the projected type plugs , these will have a 'p' in the part # , i use BCR8ES on alu heads , iron heads will be a different part number , maybe get a couple of sets (BCR7ES/BCR8ES) , 125/150 hit should be fine using the -7s , not sure if part numbers are different in United States , had issues with this before.
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: 602heavy] #873588
12/07/10 06:10 PM
12/07/10 06:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
R5671A-9 8 heat range is a little hot for NOS IMO.
Leon
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: Leon441] #873589
12/07/10 06:19 PM
12/07/10 06:19 PM
UK
602heavy Offline
602heavy  Offline
UK
Leon
Just a little concerned the OP will keep taking fuel away if using the -9s on that small a shot.
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: gsmopar] #873590
12/08/10 12:10 PM
12/08/10 12:10 PM
ellenwood,georgia
K
kdhull Offline
kdhull  Offline
K
ellenwood,georgia
perhaps this might help.
6345261-moprplugs.doc (130 downloads)
Re: Nitrous Plug, RB Edelbrock RPM heads [Re: kdhull] #873591
12/08/10 12:30 PM
12/08/10 12:30 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Thanks!!!!!!
