proper torque converter support #873551
12/07/10 12:52 PM
12/07/10 12:52 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
I presently have the engine out of my car, but the 727 is still in the car. Is it bad to keep the torque converter on the transmission for an extended period of time? To me the advantage of not removing it is that when I refire the engine after reassembly I can direct my attention to the engine instead of worrying about getting trans fluid back in. However, was unsure if the weight of the converter on the input shaft was bad.....could it just be tied up to a bellhousing bolt hole using wire or is this just asking for trouble?
Re: proper torque converter support [Re: BTTG] #873552
12/07/10 12:58 PM
12/07/10 12:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I like to remove it. The weight hanging in the seal and bushing is not (imo) a good thing.
Re: proper torque converter support [Re: MoparforLife] #873553
12/07/10 04:53 PM
12/07/10 04:53 PM
scratchnfotraction Offline
pull it
good idea to swap in a new seal when it goes back together..cheap insurance
when I goes back in,make sure it engages the 2 steps to slide it all the way back
did you mark the flex plate before removal?
makes it a one step hook up if you did
you can tie the tranz up with wire if you need to move it
Re: proper torque converter support [Re: scratchnfotraction] #873554
12/07/10 06:03 PM
12/07/10 06:03 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Thanks guys. I'll drain and pull it.
I did mark the flywheel.....
and will change the seal while it is accessible. Is this just called the front seal?
Re: proper torque converter support [Re: BTTG] #873555
12/07/10 06:07 PM
12/07/10 06:07 PM
yes,front pump seal
I like to pay the little extra and get one from the dealer,mush better than the cheapo seals
Re: proper torque converter support [Re: scratchnfotraction] #873556
12/08/10 12:59 AM
12/08/10 12:59 AM
yes,front pump seal
X2
