E440 HP
#873337
12/06/10 11:51 PM
12/06/10 11:51 PM
Posts: 151 ohio
Rich970
ohio
i have a 440 block that has E440 12 13 2 stamped on the pad.casting # 2536430-10 date 11-14-68. the vin number on the rail is CH43K9F187976. when you check the vin it comes back as a http://www.decodethis.com/VINDecoded/tabid/53/Default.aspx?vin=CH43K9F187976 chrysler newport,300,newyorker. someone said it could not be a hp block. didnt they put hp engines in full size cars also ?
Re: E440 HP
[Re: Rich970]
#873338
12/06/10 11:58 PM
12/06/10 11:58 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
350 HP TNT motor..
I am truckless..
Re: E440 HP
[Re: Rich970]
#873343
12/07/10 02:24 AM
12/07/10 02:24 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
pppssssttt , the difference between a HP and non HP 440 is the 2 stamps H and P .
Yes they did put the 440 HP in the big cars if ordered , this one was not .
Re: E440 HP
[Re: Rich970]
#873347
12/07/10 09:15 AM
12/07/10 09:15 AM
Posts: 1,183 eganville ont
440beep
eganville ont
Valve Springs W/ DAMPER cam 4640 carter AVS 750 cfm lp Valve Springs no DAMPER 600 holley
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
