A8 block info
#873264
12/06/10 09:13 PM
12/06/10 09:13 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Found a new unused block I would like to purchase but cant find any info what so ever on it. It is an A8 with 60 mm cam and comes with front geardrive. part # is P4510051. Not the same # as my block but looks exactly the same. Anyone know where to find info? nothing came up on GOOGLE!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: A8 block info
[Re: W8n2DustU]
#873265
12/06/10 10:17 PM
12/06/10 10:17 PM
Posts: 437 south central pa
bdaz smblk
south central pa
The number on the block isen't a part#.It is the casting number.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: A8 block info
[Re: Leigh]
#873267
12/07/10 09:01 AM
12/07/10 09:01 AM
W8n2DustU
San Angelo, Texas
Is the part # located on them anywhere?
Re: A8 block info
[Re: DemonDust]
#873270
12/07/10 11:01 AM
12/07/10 11:01 AM
W8n2DustU
San Angelo, Texas
I have used one for the past 3 years. Its simple! Bolt the starter to the midplate. Best Mopar block available in my opinion. Never a single issue. Ran it with a 425 shot of NOS. And 38# of boost with a procharger. Never an issue.
Re: A8 block info
[Re: DemonDust]
#873272
12/07/10 12:48 PM
12/07/10 12:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If thats the sprint car block is the front cover and gear drive still available... I sold my alum block years ago... but I was offered one the other day at a very good price but heard the cover and drive isnt available
Re: A8 block info
[Re: MR_P_BODY]
#873273
12/07/10 02:11 PM
12/07/10 02:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Mike I looked into just machining everything off the front. Make a provision out of billet to use a Webber belt drive. Weld or bolt it to the aluminum block. Never heard any complaints with the gear drive but I would prefer the belt.
The limited bore and deck heights are the only reason I never ran the alluminum block.
Re: A8 block info
[Re: W8n2DustU]
#873274
12/07/10 06:25 PM
12/07/10 06:25 PM
bdaz smblk
south central pa
I have ran a alum block for the last 8 years.starter bolts to the trans not the block.
Re: A8 block info
[Re: bdaz smblk]
#873277
12/07/10 06:53 PM
12/07/10 06:53 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I know that. The aluminum sprint car block I had didn't have the little radius in the block for a starter. The block came straight off the pan rails and made a square corner. You couldn't bolt a starter to the bellhousing.
Re: A8 block info
[Re: DemonDust]
#873278
12/07/10 07:10 PM
12/07/10 07:10 PM
W8n2DustU
San Angelo, Texas
This one has the gear drive and 60 mm cam blank with it. I would think it is worth the $4500 asking price.
