Titanium question #873230
12/06/10 09:02 PM
12/06/10 09:02 PM
Edmonton alberta Canada
mr. 63plymouth Offline OP
Hi all, just wondering what the min. thickness of titanium is suppose to be for the sheild between the trunk of a car and the back seat area? (NHRA)
Hope someone could help me!! Thanx.
Re: Titanium question [Re: mr. 63plymouth] #873231
12/06/10 09:20 PM
12/06/10 09:20 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Do it at least 032 or don't worry about it cause they'll never check it Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Titanium question [Re: mr. 63plymouth] #873232
12/06/10 10:45 PM
12/06/10 10:45 PM
I would use the same thickness as steel.
Re: Titanium question [Re: mr. 63plymouth] #873233
12/07/10 01:34 AM
12/07/10 01:34 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Expensive choice of material!
8.30's @3400 lbs
Re: Titanium question [Re: Mike Swann] #873234
12/07/10 01:44 AM
12/07/10 01:44 AM
Upland, California
Spode Offline
Spode  Offline
Upland, California
cheaper than unobtainium
Re: Titanium question [Re: Mike Swann] #873235
12/07/10 02:18 AM
12/07/10 02:18 AM
I agree,but I kinda dont like your typical alum. race car stuff!!!!Different is good!!!!
Re: Titanium question [Re: mr. 63plymouth] #873236
12/07/10 02:21 AM
12/07/10 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Play it as alum... IF a tech guy were to look at it
he would see it as alum... JMO
Re: Titanium question [Re: MR_P_BODY] #873237
12/07/10 08:06 AM
12/07/10 08:06 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
What benefit is there running titanium in this application?
Alan Jones
Re: Titanium question [Re: LA360] #873238
12/07/10 01:17 PM
12/07/10 01:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You get to tell people about it, that's why I use plutonium.
Boffin Emeritus
Re: Titanium question [Re: mr. 63plymouth] #873239
12/07/10 01:54 PM
12/07/10 01:54 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Unless you have a connection, titanium is gonna cost you several hundred dollars, at least for a piece like that. Why not just use alum. & cover it with 1/16in plastic ($8.00), carpet or thin speakerboard (it'll look factory). When the tech guy inpects you, show him the piece from the rear so he can verify it's alum. & leave it at that....
Re: Titanium question [Re: polyspheric] #873240
12/07/10 02:07 PM
12/07/10 02:07 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
yep titanium is kind of expensive. dont forget its horrible to cut or drill,welding it should be fine as long as its not space or military spec welds required. dont have alot of excperience with it but i can tell you its a beutifull metal to bend in tubeform with the right tooling
Re: Titanium question [Re: mr. 63plymouth] #873241
12/07/10 02:13 PM
12/07/10 02:13 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Not when there's no reasonable explanation other than bragging rights.
Unless you're the fastest guy in your class and winning every event, this kind of expenditure will only get all the other racers laughing at you.
Re: Titanium question [Re: Stanton] #873242
12/07/10 03:18 PM
12/07/10 03:18 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
You can always place a placard next on which you can explain the reasoning is to people that you have a titanium sheet between the trunk and back seat but do to it's location it cannot be seen.
home of the
Sox and Martin Hemi Duster
Re: Titanium question [Re: Stanton] #873243
12/07/10 03:35 PM
12/07/10 03:35 PM
Holy!!! Just ask for a QUESTION on here and this is what I get from some of you!!!!! The way some are responding it sounds like Im spending YOUR $$,others seem jealious or something??? I dont know, just asked a question about thickness,not your opinion on what or what not to use!!!! THanx for the others that helped me!!!
Re: Titanium question [Re: mr. 63plymouth] #873244
12/07/10 03:46 PM
12/07/10 03:46 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
I think some of the responses is due to the fact it IS an exotic metal & expensive at that! HEY, if you got it & want to spend it, have at it! I just think that in the world of serious Stock Elim. (assuming you're in that group) that perhaps the money could go elsewhere.
For me, that would mean engine development, chassis lightening or even acid-dipping (let's face it, it DOES go on!) I don't think you'll save all that much between titanium & the minimum thickness of alum. you could get away with.
Of course, you could do what I saw once---a guy got some CARDBOARD , spray painted it flat silver & told Tech it was alum. He got away with it! .
If your car is a "price is no object" kind of rig (good for you BTW) I'm SURE you could find other/better ways to go faster. Of course I'm sure some REAL old guys could chime in with their ideas ......
Re: Titanium question [Re: hemicop] #873245
12/07/10 04:16 PM
12/07/10 04:16 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
The density of TI is .17 lbs. per cu. in., so if you made a panel .032 thick that was 6' X 3' in area, the panel would weigh 14.1 lbs.
If the same panel were made in .040 AL, it would weigh 10.16 lbs.
So there is no advantage to building a firewall from TI, unless you have some free sheets and access to carbide cutters and bits.
Re: Titanium question [Re: cgall] #873246
12/07/10 04:18 PM
12/07/10 04:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
So it should be better and give more time till flame blows through. Use it if you got it
Re: Titanium question [Re: ademon] #873247
12/07/10 04:38 PM
12/07/10 04:38 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
I dont know what your ti callout is. I have exp w/6al-4v as stated it's very hard and definitly wont ding up or oil can like al will, be careful when grinding on it in a confined space as the sparks will ignite the off fall dust like flashpowder. Of course drill for fasteners slow (300rpm or less) and expect to eat up cutters. It cleans up well w/120 grit paper and has alot of springback so it's very forgiving,good luck.
Re: Titanium question [Re: mr. 63plymouth] #873248
12/07/10 04:40 PM
12/07/10 04:40 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
right off you had two correct answers .
cost was mentioned ,then you made the statement
which really influenced my reply to reflect directly back at it. what is or why titanimum play a part in being different if it has no use or application in an area.
Had you said something like less weight, more strength ,better finished look or even I like it better.
I could not see it being the "different" as part of the answer I would expect. a different that only you would know ?? it made no sense to me.
In response to a remark about how you spend anyone's money : around here if you get to help someone save money as oppsed to putting in an un needed area it's a plus
JEALOUS sorry he's not here where I live
sometimes if it hit ytou in a wrong way we / I don't give conventionl answers oo make light of something. it's all in fun don't be so thin skinned.
Re: Titanium question [Re: HEMIFRED] #873249
12/07/10 05:25 PM
12/07/10 05:25 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
Small piece of titanium in my neck cost over $100,000. But I did find out that you can polish it & get different colors.
Seriously, go for it if that's what you want, but like others have said it WILL be expensive.
