74 Dart heater motor R/R help... #873060
12/06/10 04:43 PM
12/06/10 04:43 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
Hi all. I have a 74 Dodge Dart Swinger. Can the heater/AC fan motor be removed by unbolting it from the firewall and pulling straight out? Or, do I have to remove the squirrel cage from the inside first? I've never had to do this before and have never seen it done. I have to remove the passenger side 440 valve cover to adjust valves.
Thanks, Russ
BigBlock 74 Swinger
Re: 74 Dart heater motor R/R help... [Re: bb74swngr] #873061
12/06/10 07:55 PM
12/06/10 07:55 PM
I'm pretty sure you unbolt/take off the retainer ring and it comes right out
Re: 74 Dart heater motor R/R help... [Re: RapidRobert] #873062
12/06/10 09:27 PM
12/06/10 09:27 PM
Missouri
mopar addict
mopar addict
Missouri
Thank you Robert! We didn't make it to the Mopar show up in Omaha this year, did you get to go? We sure had a good time last year.
Russ:)
BigBlock 74 Swinger
Re: 74 Dart heater motor R/R help... [Re: bb74swngr] #873063
12/06/10 10:02 PM
12/06/10 10:02 PM
You're welcome. No I did not make it up there, got too much going on
