Installing deep sump in gas tank.. used tank ok?
#873034
12/06/10 04:00 PM
12/06/10 04:00 PM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
I am going to use a deep sump pan for my stock gas tank. Can this be done to a used tank or only a new tank? Don't want it to blow up when welding etc. Thanks.
RS23L7 4-Speed
Re: Installing deep sump in gas tank.. used tank ok?
[Re: Mopar_Mike]
#873035
12/06/10 04:04 PM
12/06/10 04:04 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
If it's been empty and sitting open for a day or so it'll be OK. I drained mine, rinsed it out w/ water, and let it sit outside for about 24 hours before we welded the sump on it.
[Re: an8sec70cuda]
#873036
12/06/10 04:20 PM
12/06/10 04:20 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
dry solder. don't weld. welding will open it to rust as well.depdending on the fuel you're using.
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Mopar_Mike]
#873038
12/06/10 04:51 PM
12/06/10 04:51 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I would remove the pickup and sender as well as the filler tube and use a vacume cleaner that you can blow air from through the tank when applying heat,(don't try and suck air out of the tank with the vacume cleaner ) that or use nitrogen(not NOS ) or carbon monoxide out of a fire extinguisher as a filler gas to displaced the oxygen while working on the tank with heat
[Re: an8sec70cuda]
#873040
12/06/10 06:47 PM
12/06/10 06:47 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
After washing it a few times and letting it dry in the sun for two days I took a piece of flex hose and ran it from my pit bike exhaust into the tank and let it idle for 1/2 an hour. Probably overkill but better safe than sorry.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
