Header extensions........anybody run em? #872591
12/06/10 12:22 AM
12/06/10 12:22 AM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
Wondered if many here run header extensions. What were the results? How do you know if you need them? Length? Pics? Thanks in advance
Curator at Adams County Speed Shop
Re: Header extensions........anybody run em? [Re: 340man4ever] #872592
12/06/10 12:28 AM
12/06/10 12:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont run a bolt on extension but I run the numbers
through my header program and then make them that
length when I build my headers
Re: Header extensions........anybody run em? [Re: 340man4ever] #872593
12/06/10 12:32 AM
12/06/10 12:32 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We run them on our heavy cars.It helps a little on the bottom.Usually12" to 14" on the wedges and 14"to 18" on the Hemis.On the chassis cars we don't run anything past the collector.
Re: Header extensions........anybody run em? [Re: B G Racing] #872594
12/06/10 12:49 AM
12/06/10 12:49 AM
Creston, Iowa
3
Creston, Iowa
My Dart weighs in the area of 3300 lbs race ready. I am running McCandless (Pro Parts) headers currently. Engine is stock stroke 440 zero decked with 915 heads (11.25 compression). Cam is DC 590. Thought the extensions might be worth exploring?
Re: Header extensions........anybody run em? [Re: 340man4ever] #872595
12/06/10 12:56 AM
12/06/10 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most headers are way to short on the collector and
too long on the primaries... you could use about 16"
from the end of the primaries to the end of the collector
Re: Header extensions........anybody run em? [Re: MR_P_BODY] #872596
12/06/10 01:00 AM
12/06/10 01:00 AM
Creston, Iowa
3
Creston, Iowa
Mr P-Body your engine and headers in the pic above are a real work of art! Thank you for the input
Re: Header extensions........anybody run em? [Re: 340man4ever] #872597
12/06/10 01:17 AM
12/06/10 01:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... they work
Re: Header extensions........anybody run em? [Re: 340man4ever] #872598
12/06/10 03:58 AM
12/06/10 03:58 AM
Every car(Mopars only ) that I have added collector extensions on have ran faster, SB, BB or Hemi, stick or automatic trans I did find on my1963 415 HP M.W. NHRA stocker that I could add six inches primary extensions or add 12 inches of collector extensions, but not both, and get the same results That was on a set of the older two inch Hooker race headers with 3.5 inch collectors with no collector flanges, the extensions extensions slid over the collectors try the extensions on yours, make sure their longer than you think you need and then cut them off where needed
Re: Header extensions........anybody run em? [Re: Cab_Burge] #872599
12/06/10 04:50 AM
12/06/10 04:50 AM
@ the shop
E
E-85 408 DART Offline
E
@ the shop
for the night shift !!
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: Header extensions........anybody run em? [Re: E-85 408 DART] #872600
12/06/10 12:21 PM
12/06/10 12:21 PM
tboomer Offline
tboomer  Offline
I have the old primary 2" tubes like Cab is talking about....You are welcome to try them if you want..
