ignition recomendation #872487
12/05/10 10:26 PM
12/05/10 10:26 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I need a complete ignition system for a 69 GTX. Engine is 500 inch stroker. It should not rev past 6500. It is a torque engine. In the past I have always used the MP electronic conversion kit but this time I was thinking something different. What do you use and are you happy with it? Also, dose anyone use a distributer with the ECU built into the dist? I would think it would be a cleaner look?? Your thoughts
Re: ignition recomendation [Re: frank] #872488
12/05/10 11:31 PM
12/05/10 11:31 PM
scratchnfotraction Offline
cant beat the new billet ready to run dizzys with matching coils & wires from firecore
top shelf and is made by a member here
sunroofgtx
sponcer here on moparts also IIRC
Re: ignition recomendation [Re: frank] #872489
12/05/10 11:38 PM
12/05/10 11:38 PM
MS, USA
K
killercoronet Offline
K
MS, USA
Im curently running a DUI ignition on my 440. it has the built in coil and all that. So far i love it, it cleans up the engine compartment and they built it to your engine specs.
Re: ignition recomendation [Re: killercoronet] #872490
12/05/10 11:53 PM
12/05/10 11:53 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Ya I'd like a cleaner looking engine bay. I'll look into DUI. Thanks
Re: ignition recomendation [Re: frank] #872491
12/05/10 11:55 PM
12/05/10 11:55 PM
pertronix ignitor II w flamethrower coil
Re: ignition recomendation [Re: RapidRobert] #872492
12/05/10 11:57 PM
12/05/10 11:57 PM
that will work i bet
pertronix all the way to 7200rpm
keep you stock point dist too boot
Re: ignition recomendation [Re: frank] #872493
12/06/10 09:39 AM
12/06/10 09:39 AM
GA
Boosted Offline
Boosted  Offline
GA
440source billet distributor and a 6al will do the job just fine.. And is very affordable..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: ignition recomendation [Re: scratchnfotraction] #872494
12/06/10 06:06 PM
12/06/10 06:06 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
sunroofgtx
x2
