73 Charger with power steering and 71 440 block problem #872407
12/05/10 09:14 PM
12/05/10 09:14 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
What sort of power steering brackets are needed to allow this bolt on to the block? My neighbor went from a mid 70's block to a 71 casting date block with no provisions to bolt the power steering unit.
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872408
12/05/10 09:56 PM
12/05/10 09:56 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i think the ps brackets bolt to the water pump housing not the engine block
Re: 73 Charger with power steering and 71 440 block problem [Re: Joesixpack] #872409
12/05/10 10:00 PM
12/05/10 10:00 PM
Phoenix, AZ
Phoenix, AZ
that is what leads me to believe that brackets from a different year or something is what he needs to get it to work. The pump/brackets are original ones to the car(1973?.
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872410
12/05/10 10:09 PM
12/05/10 10:09 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
The same brackets that he took off should bolt up.Doing something wrong year shouldn't matter.
Re: 73 Charger with power steering and 71 440 block problem [Re: gtx69] #872411
12/05/10 10:17 PM
12/05/10 10:17 PM
Phoenix, AZ
Phoenix, AZ
not seeing how it is possible as there are no bolt holes on the front face of the block to anchor the bracket to. the mid 70's block had two bolt holes and the 71 block has none. maybe a different style power steering pump is needed???
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872412
12/05/10 10:31 PM
12/05/10 10:31 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Pictures please
Re: 73 Charger with power steering and 71 440 block problem [Re: gtx69] #872413
12/05/10 10:36 PM
12/05/10 10:36 PM
Phoenix, AZ
Phoenix, AZ
I'll see if I can get some pics but probably going to be a day or two, thanks for the responses though.
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872414
12/06/10 12:03 AM
12/06/10 12:03 AM
IA
landon1 Offline
landon1  Offline
IA
this is how mine looks...late style power steering brackets, so also use the shorter oil filter (Wix 51068) all bolts to the water pump housing
'71 Satellite Sebring 440
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872415
12/06/10 04:32 AM
12/06/10 04:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
73 and lates BB/RB has a provision to steering pump assembly in front.
Since 73s all BB belt setup was changed, as does the water pump lower outlet. That made posible fit the steering pump lower into engine bay.
SO, these blocks have a provision
all this change MAYBE because C bodies got air pumps ( emission restrictions ) around the place where earliers Steering pumps were before
note the attachment for the steering pump location since 73s... long bolt threads into the block... maybe hard to se it but it is.
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872416
12/06/10 09:55 AM
12/06/10 09:55 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Yes but stated 70's block to 71 casting not 73 block
Re: 73 Charger with power steering and 71 440 block problem [Re: Belvedere1] #872417
12/06/10 12:17 PM
12/06/10 12:17 PM
Shoreline, Washington
72roadrunnergtx Offline
Just pick-up a set of pre-73' Saginaw pump brackets designed to mount to the water pump housing. If you can't locate originals there several reproductions available . Should look something like this;
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
