Page 5 of 5 1 2 3 4 5
Re: DON'T ASK ME HOW I KNOW [Re: WILD BILL] #871872
12/09/10 11:05 PM
12/09/10 11:05 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
And just to show I'm not immune to my own stupidity,
LORD TELL WHY WOULD WE EVER THINK THAT
home of the
Sox and Martin Hemi Duster
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871873
12/09/10 11:14 PM
12/09/10 11:14 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
when trying to find the right drop base air cleaner to fit when closing the hood make sure you don't assume the drop base from summit is the same as the one that worked fine yesterday from you dads car! !It will defiantly ruin your fresh hard to match custom yellow paint job and your day when the wing nut on the air cleaner dent up the center of the hood and cracks the paint .
1969 Dodge Charger 1969 Dodge Superbee
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871874
12/10/10 01:06 AM
12/10/10 01:06 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: DON'T ASK ME HOW I KNOW [Re: WILD BILL] #871875
12/10/10 09:34 AM
12/10/10 09:34 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
When pulling a large gooseneck trailer with a Cummins turbo diesel, the trailer will pull exactly the same all the way to the track, (125 miles) with or without the 1800 lbs roadster in back.
DAMHIK
Joe
Without Data, you’re just another guy with an opinion.
Re: DON'T ASK ME HOW I KNOW [Re: sixpackgut] #871876
12/10/10 10:10 AM
12/10/10 10:10 AM
North Branch, MI, USA
notchbackcuda Offline
dont put gas in a mt dew bottle
Don't bleed brake fluid in a mountain dew bottle
Re: DON'T ASK ME HOW I KNOW [Re: notchbackcuda] #871877
12/10/10 10:29 AM
12/10/10 10:29 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
this thread has had over 2100 views yet only 85 posts.
I am amazed at how many are innocent and have nothing to add.
home of the
Re: DON'T ASK ME HOW I KNOW [Re: kdhull] #871878
12/10/10 10:45 AM
12/10/10 10:45 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
When checking the fluid level in your Dana 60 which has a slight cover leak. Never insert a "ringed finger" into the cover hole to fish around and see what the fluid level is. You will ultimately have to fashion a hooked wire to "fish" said ring from said finger out.
Don't ask me how I know!
DC
Re: DON'T ASK ME HOW I KNOW [Re: dc426] #871879
12/10/10 10:57 AM
12/10/10 10:57 AM
NY usa
540challenger Offline
NY usa
Just b/c the day before you left the hood unlatched and opened a few inches to pull the transmission when you get in the next day. Don't ASSume the next day that it is still open as your boss may have closed it after you left, so when you go to R&R the transmission the next day you will put a nice dent on the hood where the air cleaner stud is now pressing into your hood
Re: DON'T ASK ME HOW I KNOW [Re: 540challenger] #871880
12/11/10 12:40 AM
12/11/10 12:40 AM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
After installing a new Engine, Be sure to remember to install the battery hold down before taking up the road for a test drive. Or the battery could end up upside down on the header with a hole melted in it and the positive terminal stuck to the header.
Don't ask Me how I know
Re: DON'T ASK ME HOW I KNOW [Re: Mpetros] #871881
12/11/10 01:18 AM
12/11/10 01:18 AM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
I always light the top bulb, then pop the shifter into neutral (clean the plugs!!) then pop 'er back into FIRST gear, so as not to have left the tranny in THIRD gear after the burnout. Leaving in third gear REALLY kills the 60'. Don't ask me how I know......
If You Can't Be Good, At Least Be Colorful
Re: DON'T ASK ME HOW I KNOW [Re: Dago Red] #871882
12/11/10 01:53 AM
12/11/10 01:53 AM
pa
K
Kyle Reasbeck Offline
K
pa
when at the racetrack, don't blow your nose in front of a camera, dont ask fred how he knows lol
Re: DON'T ASK ME HOW I KNOW [Re: Kyle Reasbeck] #871883
12/11/10 02:12 AM
12/11/10 02:12 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
BLOW IT ???? TRY HOLD IT.
we just drove by the hog pen and were warning oncomers
home of the
Re: DON'T ASK ME HOW I KNOW [Re: sr4440] #871884
12/11/10 05:50 PM
12/11/10 05:50 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
DAMHIK
Joe
This one HAS to be the winner. I can imagine the look on your face when you opened the trailer door at the track and the car was GONE!
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: DON'T ASK ME HOW I KNOW [Re: fasteddie] #871885
12/11/10 06:52 PM
12/11/10 06:52 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
you have to circulate the anti-freeze thru the indy ez's or the ice will crack them between the exhaust ports....
don't ask me how I know.
Re: DON'T ASK ME HOW I KNOW [Re: emarine01] #871886
12/11/10 07:51 PM
12/11/10 07:51 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Don't think you cant brake a breaker bar just cause its 3/4 drive Don't ask me how I know
especially a Harbor freight bar
Re: DON'T ASK ME HOW I KNOW [Re: Crizila] #871887
12/12/10 12:05 AM
12/12/10 12:05 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
When you are all done with that compression test, don't forget to remove the screw driver you jambed down the carb to hold the throttle blades open - before you fire it up. DON'T ASK ME HOW I KNOW!!!
...Definitely gets your adrenelin going don't it!!!!
Bin-there-done-that!!
Re: DON'T ASK ME HOW I KNOW [Re: superwrench] #871888
12/12/10 12:46 AM
12/12/10 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Remember to bring your trailer keys with you to the
track... the back door locks do get pricey... and hard
to find bolt cutters at the track... dont ask how I know
Re: DON'T ASK ME HOW I KNOW [Re: MR_P_BODY] #871889
12/16/10 11:59 PM
12/16/10 11:59 PM
iowa
rook440 Offline
rook440  Offline
iowa
