3.3 or 3.8 guys #871242
12/04/10 04:23 PM
12/04/10 04:23 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
...is one motor better than the other ? Any HORRID service issues ? ....how about tranny probs ? ... 2003 year
Re: 3.3 or 3.8 guys [Re: dOc !] #871243
12/04/10 05:03 PM
12/04/10 05:03 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
They are the same in terms of reliability.
Rock solid pushrod engines. Unrefined when compared to their multivalve OHC competition from Japan, but no major issues to speak of.
And no timing belt to change.
The A604 transmissions have their problems, but by that year they were far better than when first introduced.
MB
Re: 3.3 or 3.8 guys [Re: dOc !] #871244
12/04/10 06:46 PM
12/04/10 06:46 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Noticeably more power with the 3.8, both solid engines. Keep the oil clean (mine likes NAPA synthetic) and youre good to go.
My 01 Minvan has a 5 pinion planetary, earlier ones had 3 or 4 and failed. I assume an 03 would have a 5 as well.
Later 604s have the cross pin retiainers installed. The pin used to hold the cross shaf tin would brake and the cross shaft would come out. Game over, my 01 had the retainers. Again, I assume an 03 would as well.
There is a thurst bearing in the convertor that fails on some 604s. When it fails, the beairng pieces tear up the lock up clutch, and thos clutch peices plug up the lube circuit. Game over for the planetary. It tosses a code, so you get some warning.
I use valvoline ATF+4 in my 604s. Dont use dextron or any additives.
Dump the OEM trans cooler in the radiator, and go solely with an auxiliary cooler. Space the cooler away from the radiator if you can.
All in all, not a bad engine/trans package. I am currently puting a 3.8/604 into a 99 minivan that originally had a 3.0/403 trans. SHort wheel base van, only options were tinted windows,AC and Cruise. My 1 Town and Country will get 26/27 MPG on the highway - used to get 22-24 until I rebuilt the trans (lock up clutch and bearing failure) I used the better friction material and a hand built convertor (no bearing) and my MPG went way up. Hopefully the bigger engine in the light weight van will exceed my loaded town and country mileage. 3.0 would barely get 19 mpg with no passengers or cargo.
Re: 3.3 or 3.8 guys [Re: NTOLERANCE] #871245
12/04/10 07:34 PM
12/04/10 07:34 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
THX guys .....
which motor is a better deal and will produce better MPG ? ...and is a AWD Caravan something to look at ?
Re: 3.3 or 3.8 guys [Re: dOc !] #871246
12/05/10 09:50 AM
12/05/10 09:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Doc I have a 3.3 in the 96 Concord.Never any problems.I bought it new and on the road it still gets 30 MPG.My kid was averaging 25 city and highway.My niece has a 3.8 in her mini van.Gets about 28 highway.Rocky
Chrysler Firepower
Re: 3.3 or 3.8 guys [Re: dOc !] #871247
12/05/10 12:02 PM
12/05/10 12:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My SWB '04 Town and Country 3.3 gets 23 mpg, even fully loaded with rearend parts.
2WD vans get around fine with studded snow tires.
Re: 3.3 or 3.8 guys [Re: DoctorDiff] #871248
12/05/10 12:58 PM
12/05/10 12:58 PM
Ohio
ScottG Offline
ScottG  Offline
Ohio
I have had both 3.3 and 3.8. Both GREAT engines, the 3.3 did about 1-2 MPG more. But the 3.8 has a little more get up and go. I have a 3.8 now but I would not hesitate to buy a 3.3 agian.
Scott
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: 3.3 or 3.8 guys [Re: ScottG] #871249
12/05/10 06:03 PM
12/05/10 06:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
3.3 and 3.8 are basically the same engine apart from the additional .5L displacement. I have heard that the AWD minivans are pigs on fuel.
Re: 3.3 or 3.8 guys [Re: DaytonaTurbo] #871250
12/05/10 07:00 PM
12/05/10 07:00 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
THX again guyz ...
WHEN did they get transmissions more-or-less trouble free? Are there earlier years to absolutely stay-away from ?
And is the 3.3 the same as way back in the early 90's ? IIRC ... there were big-time cyl head issues then.
ARE THERE any other things to consider? .... I remember a topic a while back about a Stratus? ... where changing a water-pump was a HUGE job. 2700$ ..... or something like that - at a dealer.
DON'T want anything like that. I have had it EZ so far ... all my daily-driver stuff that I have had so far(lately) have been 2.2/2.5 4-bangers.
Re: 3.3 or 3.8 guys [Re: dOc !] #871251
12/05/10 08:26 PM
12/05/10 08:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I only had 1 3.8 with a head problem at work.The rocker stand sheared and needed a new head.The water pump is as easy as can be.Its just a disc type like the early BB pump.Only real problem was the rear heater lines.I fixed probally 30 at work.We were just cutting the bad steel section out and using a longer rubber hose.Took about an hour start to finish.Rocky
Chrysler Firepower
Re: 3.3 or 3.8 guys [Re: dOc !] #871252
12/06/10 10:40 PM
12/06/10 10:40 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
We use a 3.8 in a 99 Caravan to tow cars from St. Louis, 125 miles away. 208k miles, 20 mpg towing, tons of room in the back to haul parts with the seats removed. Had to change the torque converter. And bypass the tranny cooler in the radiator when it cracked. That's about it.
One of the solidest power packages I have ever had.
Master, again and still
Re: 3.3 or 3.8 guys [Re: DaveRS23] #871253
12/07/10 12:54 AM
12/07/10 12:54 AM
Woodburn Oregon
Two Lane Offline
Two Lane  Offline
Woodburn Oregon
I agree- the 3.0 were junk but the 3.3/3.8's are virtually bulletproof- I only have to change the t-chains around 200K. the trannys are another story
"Do you know why I stopped you?"- "No" - "Your license plate was laid down"- "Oh that,- that only happens when I Floor it"
Re: 3.3 or 3.8 guys [Re: dOc !] #871254
12/07/10 12:58 AM
12/07/10 12:58 AM
Woodburn Oregon
Two Lane Offline
Two Lane  Offline
Woodburn Oregon
THX guys .....
By all means STAY AWAY from the AWD trans! I worked for a few wrecking yards and based on demand- we couldn't keep them in stock.
Re: 3.3 or 3.8 guys [Re: dOc !] #871255
12/10/10 05:19 PM
12/10/10 05:19 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Re: 3.3 or 3.8 guys [Re: dOc !] #871256
12/11/10 03:18 PM
12/11/10 03:18 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The wifes 05 Grand Caravan, 53,000 miles. Burns about a third a quart of oil per tank of gas. Anyone ever have this problem?
Re: 3.3 or 3.8 guys [Re: NTOLERANCE] #871257
12/11/10 03:25 PM
12/11/10 03:25 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
It's the exact same gear carrier that was used in a 7 1/4" rear end, lousy design.
Re: 3.3 or 3.8 guys [Re: tmef] #871258
12/11/10 03:28 PM
12/11/10 03:28 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I put a new PCV valve in our '05, problem went away.
Re: 3.3 or 3.8 guys [Re: Dave Watt] #871259
12/11/10 10:21 PM
12/11/10 10:21 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Wifes 03 grand caravan has 227,732 miles no engine or trannie problems,just normal mat. have a few other customers with them just over 200k no major problems.both engines are great,same engines,3.8 bigger bore.
Re: 3.3 or 3.8 guys [Re: GarageDodge] #871260
12/11/10 10:42 PM
12/11/10 10:42 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
We used to get 33 MPG highway in out '94 Intrepid ES w/180k+ on the odo. I found it had plenty of power when called upon. Plenty.
