1970 440-6 timing #87119
07/11/08 08:37 AM
07/11/08 08:37 AM
Anonymous OP
Anonymous OP
I would like to retard the timing 2-3*, is that counter clock wise and about 1/4" turn
Re: 1970 440-6 timing #87120
07/11/08 09:05 AM
07/11/08 09:05 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Right direction. 2 or 3* is barely moving the dist at all so if you feel it turn, you probably went too far. I would get a timing light so you can tell how too far you went and put it back where you want it. Anything else is just guessing and unless you have done this a bunch, you will likely guess way wrong.
Kevin
Re: 1970 440-6 timing [Re: Twostick] #87121
07/11/08 09:15 AM
07/11/08 09:15 AM
Anonymous OP
Anonymous OP
thanks, that is what I thought
Re: 1970 440-6 timing #87122
07/11/08 12:52 PM
07/11/08 12:52 PM
pgh pa
captaindodge Offline
pgh pa
All you need to do is paint a mark on the base of distributer and the eng block and you will know where you were and how far you moved the dist.
