Wilwood or Aerospace Brakes???
#871155
12/04/10 03:22 PM
12/04/10 03:22 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What are you running on the rear and which is better for street/ strip car???
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Wilwood or Aerospace Brakes???
[Re: 65 Hemi]
#871156
12/04/10 04:11 PM
12/04/10 04:11 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I had Aerospace front and rear on my street/strip Duster, vented, slotted and drilled rotors in the front, and solid drilled rotors in the rear. The thing about them is they have self-retracting calipers, so you have to double pump them in order to stop the car. They make them like that to eliminate friction on a drag car. But, not a great idea on a street driven car if you have to make a panic stop. Now they make Pro Street brake kits that have larger diameter rotors. Call them and see if those Pro Street brake calipers have the self-retracting feature, or if they removed it.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: hemi-itis]
#871161
12/04/10 06:37 PM
12/04/10 06:37 PM
NEITHER
STRANGE for me.Best brakes I have used ever.
#871163
12/04/10 06:55 PM
12/04/10 06:55 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Are you all running the strange brakes on the street? I ended up having to use the strange rear disc setup to clear my wheels. Was told not to run them on the street but I seem to have read here before that quite a few people are indeed using them on street driven vehicles front and rear discs.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: W5Duster436]
#871164
12/04/10 07:04 PM
12/04/10 07:04 PM
No problems on the street,As long as it's not your daily driver you will be fine.
[Re: 65 Hemi]
#871167
12/04/10 07:47 PM
12/04/10 07:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have Wilwoods on the front of my Demon,they practically bolted themselves on the car,and they stop great.
[Re: W5Duster436]
#871168
12/04/10 09:16 PM
12/04/10 09:16 PM
always had good luck with wilwoods
I bought the wilwood 140-7144's with the parking brake but the darn setup would not work with my rims/backspace. The strange kit cleared so I bought them. Wish I had the parking brake as it's mostly street driven but would rather have the discs then a drum setup.
mky e brake setup didn't work on my rear Wilwoods either.
[Re: bigdad]
#871171
12/06/10 03:36 AM
12/06/10 03:36 AM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
I have Aerobrakes on the rear on the FED,No issues!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
