Wilwood or Aerospace Brakes??? #871155
12/04/10 03:22 PM
12/04/10 03:22 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What are you running on the rear and which is better for street/ strip car???
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Wilwood or Aerospace Brakes??? [Re: 65 Hemi] #871156
12/04/10 04:11 PM
12/04/10 04:11 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I had Aerospace front and rear on my street/strip Duster, vented, slotted and drilled rotors in the front, and solid drilled rotors in the rear. The thing about them is they have self-retracting calipers, so you have to double pump them in order to stop the car. They make them like that to eliminate friction on a drag car. But, not a great idea on a street driven car if you have to make a panic stop.
Now they make Pro Street brake kits that have larger diameter rotors. Call them and see if those Pro Street brake calipers have the self-retracting feature, or if they removed it.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Wilwood or Aerospace Brakes??? [Re: 65 Hemi] #871157
12/04/10 04:15 PM
12/04/10 04:15 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have willwood rear,and strange disc fronts,there both good,but eventually strange will be in front also
Re: Wilwood or Aerospace Brakes??? [Re: fishy340] #871158
12/04/10 04:23 PM
12/04/10 04:23 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
you mean the back?
Re: Wilwood or Aerospace Brakes??? [Re: 2QUICK4U] #871159
12/04/10 06:19 PM
12/04/10 06:19 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
NO i will be goin strange all around
Re: Wilwood or Aerospace Brakes??? [Re: fishy340] #871160
12/04/10 06:32 PM
12/04/10 06:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Your already strange all around!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Wilwood or Aerospace Brakes??? [Re: hemi-itis] #871161
12/04/10 06:37 PM
12/04/10 06:37 PM
NEITHER
STRANGE for me.Best brakes I have used ever.
Re: Wilwood or Aerospace Brakes??? #871162
12/04/10 06:54 PM
12/04/10 06:54 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
think about Ebrake options on the kit as you might want 1.
Re: Wilwood or Aerospace Brakes??? #871163
12/04/10 06:55 PM
12/04/10 06:55 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Are you all running the strange brakes on the street? I ended up having to use the strange rear disc setup to clear my wheels. Was told not to run them on the street but I seem to have read here before that quite a few people are indeed using them on street driven vehicles front and rear discs.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Wilwood or Aerospace Brakes??? [Re: W5Duster436] #871164
12/04/10 07:04 PM
12/04/10 07:04 PM
No problems on the street,As long as it's not your daily driver you will be fine.
Re: Wilwood or Aerospace Brakes??? #871165
12/04/10 07:07 PM
12/04/10 07:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
always had good luck with wilwoods
Re: Wilwood or Aerospace Brakes??? [Re: Quicktree] #871166
12/04/10 07:09 PM
12/04/10 07:09 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I bought the wilwood 140-7144's with the parking brake but the darn setup would not work with my rims/backspace. The strange kit cleared so I bought them. Wish I had the parking brake as it's mostly street driven but would rather have the discs then a drum setup.
'71 Dodge D100
'70 Dodge W100
Re: Wilwood or Aerospace Brakes??? [Re: 65 Hemi] #871167
12/04/10 07:47 PM
12/04/10 07:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have Wilwoods on the front of my Demon,they practically bolted themselves on the car,and they stop great.
Nautilus Racing-
Re: Wilwood or Aerospace Brakes??? [Re: W5Duster436] #871168
12/04/10 09:16 PM
12/04/10 09:16 PM
mky e brake setup didn't work on my rear Wilwoods either.
Re: Wilwood or Aerospace Brakes??? #871169
12/04/10 09:50 PM
12/04/10 09:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
NEITHER
I hope you are correct, I just ordered and will receive on Monday the complete Strange front and rear disc set-up including the master cylander from Bobs Pro Fab.
Re: Wilwood or Aerospace Brakes??? [Re: 65 Hemi] #871170
12/05/10 11:52 PM
12/05/10 11:52 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Doug, clean out your PM box
full, I can not reply
Re: Wilwood or Aerospace Brakes??? [Re: bigdad] #871171
12/06/10 03:36 AM
12/06/10 03:36 AM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
I have Aerobrakes on the rear on the FED,No issues!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Wilwood or Aerospace Brakes??? [Re: fed] #871172
12/06/10 03:35 PM
12/06/10 03:35 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have Wilwoods on the front and back. Parts are okay whwn they fit, but the company is the biggest %$#@%&* you ever came across. NEVER WILWOOD AGAIN FOR ME!!!!!!!
Re: Wilwood or Aerospace Brakes??? [Re: markz528] #871173
12/06/10 04:30 PM
12/06/10 04:30 PM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
I agree and heard it many many times! Aerospace all the way! Wilwood is nothing more than chines overvalued stuff
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
