How I identify a Max/Street Wedge engine? #87077
07/11/08 01:39 AM
07/11/08 01:39 AM
DE
toniflexen Offline OP
DE
Hello,
could anybody descripe me, how I identify a Max Wedge or a Street Wedge engine?
Regards Flo
www.Mopar-Crew-Gifhorn.com
1965 Plymouth Satellite
Re: How I identify a Max/Street Wedge engine? [Re: toniflexen] #87078
07/11/08 01:52 AM
07/11/08 01:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Don't rely on the casting #'s, they are not specific to any one engine.
The id pad on the top drivers front is the best way to spot either.
1964 Street Wedge engine will be stamped V 42 HP and a date below it somewhere. These engines were ALWAYS painted Turquoise.This engine had chrome valve covers and air cleaners with no snorkels and a tach drive distributor with no cable, just a cap over it. All were single 4 barrel intakes with a small 625 Carter carb and log style exhaust manifolds.
1965 426 Street Wedge would be stamped A 426 HP and then a date code below, same color engine. Both years carried regular 516 small valve wedge heads with heat cross over passages, nothing special.
Max Wedges were all painted Race Hemi Orange and had different font size stampings and characters. They varied based on which compression they came with. Here's a pic of an original Max Wedge pad for a comparison.
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87079
07/11/08 01:59 AM
07/11/08 01:59 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a (poor quality) Street Wedge pad, notice the smaller font. To the right of the V there would have been a 42 (no "6") but it appears that someone either accidently or purposely beat on the pad which obscured it
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87080
07/11/08 02:03 AM
07/11/08 02:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Max Wedge Intake
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87081
07/11/08 02:08 AM
07/11/08 02:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Street Wedge
Re: How I identify a Max/Street Wedge engine? [Re: toniflexen] #87082
07/11/08 02:12 AM
07/11/08 02:12 AM
Before I start a riot on this....
Max Wedges came in 2 varieties...413 and 426.
The naysayer's...do some more homework.
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87083
07/11/08 02:17 AM
07/11/08 02:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
64 Street Wedge
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87084
07/11/08 02:19 AM
07/11/08 02:19 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
64 Max Wedge
....And yes, "Stage I" 413 (1962 Max Wedge) and 426 (1963, "Stage II" & 64 "Stage III" Max Wedge).
Other than bore size there were'nt many differences between them, mostly subtle changes. 64's had 518 heads, 62 & 63's had 286 heads, 64's used 3705 carbs, 62 & (most) 63's used 3447 carbs. Late 63 & 64 cross ram designs flowed slightly better but looked basically the same as earlier versions (pic above is a 64 stage III).
Re: How I identify a Max/Street Wedge engine? [Re: ScottSmith_Harms] #87085
07/11/08 03:01 AM
07/11/08 03:01 AM
DE
DE
oh thank you all for your fast reply!
Regards Flo
Re: How I identify a Max/Street Wedge engine? [Re: toniflexen] #87086
07/11/08 03:36 AM
07/11/08 03:36 AM
Alabama
BigMoneyLewis Offline
Alabama
The 426 street wedge (365 hp) is stamped HP ,
and the Max wedge is stamped MP (maximum performance)
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
