Electrical on street/ strip car #870539
12/03/10 10:56 PM
12/03/10 10:56 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Do you use the stock wiring harness or aftermarket switch panel?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Electrical on street/ strip car [Re: 65 Hemi] #870540
12/03/10 11:28 PM
12/03/10 11:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Combination of both, my needs are simple. Start with key and use relays for FP/Fan and WP. mike
Re: Electrical on street/ strip car [Re: Sport440] #870541
12/03/10 11:36 PM
12/03/10 11:36 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
ditto here.
Re: Electrical on street/ strip car [Re: 65 Hemi] #870542
12/03/10 11:42 PM
12/03/10 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the car I am building for Drag Week I plan on using
most of the stock wiring harnesses but with relays...
I'll trigger the relays with the wire that normally
would go to the item(in a lot of the cases) sure I'll
need to add some
Re: Electrical on street/ strip car [Re: 65 Hemi] #870543
12/04/10 12:01 AM
12/04/10 12:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Stock harness on mine.
Re: Electrical on street/ strip car [Re: justinp61] #870544
12/04/10 12:59 AM
12/04/10 12:59 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Doug,
Interesting question, and one I'll be tackling soon!! When I bought my 62 Valiant, it was a bracket car, with moroso W/P drive, no alternator, Mp ignition, and started with the key.
My plan all along was to put it back to street/strip, but I was in a hurry to go racing! So I added a painless wiring 6 switch panel, relays, and a digital 6, and completely bypassed the stock system...
Now, I want to get the lights hooked up, alternator hooked up, and I'm trying to decide how much of the 50 year old stock harness to trust, and integrate into the plan...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Electrical on street/ strip car [Re: MoparBilly] #870545
12/04/10 04:30 AM
12/04/10 04:30 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if it were me I would eliminate the old wiring harness and use just the switches and key. thats pretty much what I did on my challenger. except I didn't use the key. but I used the overhead roll bar mounted switch panel. could have easily used factory switches. mine is wired for turn signals, lights, brake lights etc. painless kit
Re: Electrical on street/ strip car [Re: Quicktree] #870546
12/04/10 12:01 PM
12/04/10 12:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use the stock harness for lights and wipers only. Everything else is worked off of a relay panel I built in the glove box, switches are on my TA shifter console. It does use the ignition switch still.
I thought it would be cheaper to build my own relay panel. By the time I was done I could have purchased one for just a small amount more.
68 Barracuda Formula S 340
Re: Electrical on street/ strip car [Re: 65 Hemi] #870547
12/04/10 12:28 PM
12/04/10 12:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
IMHO..I think it's far easier and that you'd be way ahead using an aftermarket kit.There are several to choose from and lots of good ideas in the street rod magazines.
Nautilus Racing-
Re: Electrical on street/ strip car [Re: MoparBilly] #870548
12/04/10 12:51 PM
12/04/10 12:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Definitely, replace or bypass all the original bulkhead connectors.
Boffin Emeritus
Re: Electrical on street/ strip car [Re: polyspheric] #870549
12/04/10 01:19 PM
12/04/10 01:19 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Either way I will buy all new. Its not about the cost. I only have one chance of doing it right. I am thinking about complete aftermarket so I can hide most of the wiring.What kits have you used and how were they?
Doug
Doug
MOPAR or NO CAR!!!
