Re: Stalling when put into gear
[Re: way2fast]
#870347
12/03/10 07:35 PM
12/03/10 07:35 PM
RapidRobert
Might take out the idle mix screws (count the # of turns) & shoot a 2 second blast of starting fluid in each hole & reinstall the screws. The specs you posted sound good. I was thinking we tried the starting fluid b 4 & it didn't help
[Re: way2fast]
#870348
12/03/10 07:41 PM
12/03/10 07:41 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Apply the brakes with your left foot and try to keep it running with throttle after it tries to stall in gear, if you can keep it running with more throttle the converter probably isn't the problem.
[Re: John_Kunkel]
#870350
12/03/10 07:55 PM
12/03/10 07:55 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
What he said , if you have something setup wrong and the lockup clutch is applied it will stall when you put it in gear if your foot is firmly on the brake.
[Re: JohnRR]
#870354
12/04/10 06:32 PM
12/04/10 06:32 PM
John_Kunkel
Rio Linda, CA
Even with the lockup wire energized the converter won't lockup until after the 2-3 shift.
Converter lockup at a standstill is a hydraulic problem, leakage in the front pump area.
