will a B-body pistol grip fit in an A body #870229
12/03/10 12:24 PM
12/03/10 12:24 PM
New Brunswick Canada
copperSwinger Offline OP
Hey has anyone tried fitting a non-console b-body pistolgrip into a bench seat a-body?
Main question is will it hit the dash without modifying it
Re: will a B-body pistol grip fit in an A body [Re: copperSwinger] #870230
12/03/10 12:35 PM
12/03/10 12:35 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
You will need the '71 up B Body bench seat shifter.
Re: will a B-body pistol grip fit in an A body [Re: Mopar1] #870231
12/03/10 09:52 PM
12/03/10 09:52 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Yes they fit good
Re: will a B-body pistol grip fit in an A body [Re: bp27] #870232
12/03/10 10:59 PM
12/03/10 10:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hey, that looks cool. How does it fit your driving style? Is it close at hand?
I'm considering a swap to a different shifter handle, I could use the help.
Re: will a B-body pistol grip fit in an A body [Re: copperSwinger] #870233
12/04/10 12:48 AM
12/04/10 12:48 AM
United States
V
v269 Offline
v269  Offline
V
United States
Re: will a B-body pistol grip fit in an A body [Re: Kern Dog] #870234
12/04/10 11:00 AM
12/04/10 11:00 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Years ago I have one in my Dart (and will again)
71 bench style, non-console. In my case I cut a notch out of the handle down below the boot and bent the handle to where I was comfortable with it and then welded the notch up.
Since it is under the boot the work is out of sight. If my dusty memory is correct (the events took place 25 years ago!) I only had to move it back an inch or two tops to be comfortable.
Tried the short "e-body" style, there was far too much reaching going on...
