Winch question #869368
12/02/10 10:25 AM
12/02/10 10:25 AM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
Can anyone tell me if a Superwinch model UT3000 will be powerful enough to pull my Duster on my open trailer. The car weighs 3300 pounds with out me in it. According to their we site it should do the job. I'd like some input from some of you racers before I make a final decision.
Thanks,
Raul
Re: Winch question [Re: Aspen7695] #869369
12/02/10 10:48 AM
12/02/10 10:48 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I believe winch ratings are based on how much weight they can drag. Since your car (hopefully) rolls on wheels, the winch will never "see" 3300 lbs.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Winch question [Re: nhramark] #869370
12/02/10 11:33 AM
12/02/10 11:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have one and it pulls my challenger up fine but it's a pain in the rear to keep the cable from messing up. already replaced it twice
Re: Winch question [Re: nhramark] #869371
12/02/10 11:39 AM
12/02/10 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Everyone I've seen the rating is a vertical lift...
I've pulled a 4000# jeep on my open trailer with my
1500# rated cheapo winch
Re: Winch question [Re: MR_P_BODY] #869372
12/02/10 12:14 PM
12/02/10 12:14 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
For what its worth, I would get one bigger than what you need. You never know what may happen to the car or what you may put on the trailer. Better to spend a few dollars more now than after you have burnt up the "maybe it will work". Ask me how I know.....
Re: Winch question [Re: Dodgeguy101] #869373
12/02/10 12:27 PM
12/02/10 12:27 PM
GA
Boosted Offline
Boosted  Offline
GA
I bought an 8000# one from Tractor Supply. I have pulled everything from ford diesel pickups to station wagons with flat tires. Works great.
Tractor supply has a coupon they sent out for this week giving you 10,15 or 25% off...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Winch question [Re: Dodgeguy101] #869374
12/02/10 12:38 PM
12/02/10 12:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just buy a pulley so you can double the pulling power...
if you have enough cable it works great... if not
enough cable just have another length coiled up for
stand by use... to me its a waste of money to buy
the big dollar winch when you MIGHT use it once a year
and the pulley works if needed
