Re: Winch question
[Re: Aspen7695]
#869369
12/02/10 10:48 AM
12/02/10 10:48 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I believe winch ratings are based on how much weight they can drag. Since your car (hopefully) rolls on wheels, the winch will never "see" 3300 lbs.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
Re: Winch question
[Re: nhramark]
#869371
12/02/10 11:39 AM
12/02/10 11:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Everyone I've seen the rating is a vertical lift... I've pulled a 4000# jeep on my open trailer with my 1500# rated cheapo winch
Re: Winch question
[Re: Dodgeguy101]
#869373
12/02/10 12:27 PM
12/02/10 12:27 PM
Posts: 2,648 GA
Boosted
GA
I bought an 8000# one from Tractor Supply. I have pulled everything from ford diesel pickups to station wagons with flat tires. Works great.
Tractor supply has a coupon they sent out for this week giving you 10,15 or 25% off...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Winch question
[Re: Dodgeguy101]
#869374
12/02/10 12:38 PM
12/02/10 12:38 PM
MR_P_BODY
For what its worth, I would get one bigger than what you need. You never know what may happen to the car or what you may put on the trailer. Better to spend a few dollars more now than after you have burnt up the "maybe it will work". Ask me how I know.....
Just buy a pulley so you can double the pulling power... if you have enough cable it works great... if not enough cable just have another length coiled up for stand by use... to me its a waste of money to buy the big dollar winch when you MIGHT use it once a year and the pulley works if needed
