Re: anyone stroke a hemi crank.
[Re: johnzgarage]
#869219
12/02/10 12:43 AM
12/02/10 12:43 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I doubt you will get that much out of it. If your lucky you might see .08"-.085" gain, but your also working with a damaged crank, so it could less than that. Your wanting to use the longer 7.1 rods in this engine also. This would require custom pistons. Your talking $300-$500 worth of machine work counting re balancing. In the end you still have a stock crank that has seen major abuse. Just to save a few hundred dollars. You can find cranks out there in the $500-$600 range if you shop around some. Those engines in my eyes are just to expensive to take chances on band-aid fixes. I have NOT had any problems with the cheaper off shore cranks, and I have run them all. Eagle,440 Source,RPM etc. They just need checked.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Dodgem]
#869224
12/02/10 11:49 AM
12/02/10 11:49 AM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
I would think it could be offset ground to 4.00 easy enough when going to a Chevy 2.2 rod.
the Eagle crank I have fitted for a low deck started out as a .010 undersize on the rods and easily went out to 3.895 , used that stroke because of a miscommunication in piston CH.
[Re: Streetwize]
#869228
12/02/10 02:13 PM
12/02/10 02:13 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
well BB mopar is 2.375 journal and the Chevy is 2.20 so you have .175 to work with offset it .125 with 95% of the cut off the inside should be no problem .125 X 2 will increase the effective stroke .250 .250 + 3.750 = 4.00 I could see getting 4.050 stroke.
[Re: Dodgem]
#869229
12/02/10 02:46 PM
12/02/10 02:46 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Dodgem, no not really because you have to work from the journal centerline so the net is 1/2...like the difference between using the diameter and the raduis.
2.375/2 = 1.1875 2.2/2 =1.1
"gross" difference is .0875" x 2 =.175", by the time you allow for clean-up you typically "net" =.075-ish x 2 = .15 added to the stroke.
[Re: Dodgem]
#869236
12/02/10 06:33 PM
12/02/10 06:33 PM
Posts: 1,200 UK
602heavy
UK
Guess I had it wrong in my head. live and learn.
Just shows were only human @ the end of day , imagine being right all the time , although some guys on here are always right.
