Got a Call from the machine shop today. #869078
12/01/10 09:18 PM
12/01/10 09:18 PM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
3 weeks ago my father and I drug my 360LA block and rotating assembly to the machine shop to get hot tanked bored .030 over, new cam bearings,frost plugs, OEM crank ground and rotating assembly ballanced. Got the call today that they finished it and its ready to pick up
Now my father and I have to mock it up and figure out what I have to do to make some of Brians RHS heads fit.
Re: Got a Call from the machine shop today. [Re: 72swgnr] #869079
12/01/10 11:27 PM
12/01/10 11:27 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
have fun and good luck
Re: Got a Call from the machine shop today. [Re: 72swgnr] #869080
12/01/10 11:30 PM
12/01/10 11:30 PM
tboomer Offline
tboomer  Offline
Don't worry...I think that the "Mayor" will get ya fixed up!! Good luck!!
Re: Got a Call from the machine shop today. [Re: 72swgnr] #869081
12/01/10 11:34 PM
12/01/10 11:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sounds like someones excited,
Alright get to work and have some fun. mike
Re: Got a Call from the machine shop today. [Re: one bad fish] #869082
12/01/10 11:34 PM
12/01/10 11:34 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I will probably pick the stuff up early next week son. Future dyno fodder Dad
Re: Got a Call from the machine shop today. [Re: tboomer] #869083
12/01/10 11:43 PM
12/01/10 11:43 PM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
Ted the problem is I ordered KB-191 pistons which is a quench dome piston for open chamber heads. The RHS heads are closed chamber so after some measuring we will figure out if its better to mill the domes off or get a custom set of head gaskets from Cometic.
Original plan called for stock open chamber heads. Funny how's plans change.
Re: Got a Call from the machine shop today. [Re: 72swgnr] #869084
12/01/10 11:45 PM
12/01/10 11:45 PM
tboomer Offline
tboomer  Offline
Don't worry...Dad will fix it!!
