Re: TH400 in a big block mopar?
[Re: polkat]
#869060
12/01/10 10:22 PM
12/01/10 10:22 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
you need an adapter if you keep the GM case unless you cut the bell off and buy a Mopar bell. A 130 tooth flywheel that bolts to you Mopar but allows use of the 400 converter. a mopar mini starter works in both cases. a rear trans mount modification and driveshaft. Most do it for the added strength over a 727 . that is always a point of dicussion around here. cheaper transmission to buy HP capability per dollar .better choice of converters
and if you run brackets a powerglide works great
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#869061
12/02/10 02:17 AM
12/02/10 02:17 AM
Posts: 4,689 On the parachute mount
n20mstr
i have a t400 and only did it for two reasons, Cheaper parts ( My converter was 400.00 cheaper because its for a GM not a T flite..) And the sprag can still break but is not as prone to roll over/break in a pedaling situation..
Its just a more widely used trans and in the long run a lot cheaper. Why i really cant say, just the way it is, Id rather use a 727 because its prob a lot lighter
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#869063
12/03/10 04:47 PM
12/03/10 04:47 PM
Posts: 4,072 Mo.
racerx
Mo.
Anyone no the weight difference?
