How do you align the front end Street Strip Car` #868806
12/01/10 02:01 PM
12/01/10 02:01 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
At a point where I will be need to have the front end aligned any suggestions on set up.
FYI Ladder Bars in the rear
Re: How do you align the front end Street Strip Car` [Re: Kam*Kuda] #868807
12/01/10 02:11 PM
12/01/10 02:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When the car is completed.. with the front up 1" then
use 0 camber, as much as you can get for caster and
1/16" toe in also make sure the rear is square in
the car... at the same time you might want to get it
scaled so they can set the pre-load... I always take
mine to Jakes Automotive to get it done (Sterling Heights Mi)
Re: How do you align the front end Street Strip Car` [Re: MR_P_BODY] #868808
12/01/10 02:47 PM
12/01/10 02:47 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I would also add..take it to a place that does 4 wheel alignments as Mike is saying that it all needs to be squared up..
they use a Laser to sight it in and the rest is as Mike suggested
on my car they picked the front up to where its barely touching and zeroed the camber..
Re: How do you align the front end Street Strip Car` [Re: smokinwoody] #868809
12/01/10 03:11 PM
12/01/10 03:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I also put my weight equivalent in the seat and 1/2 tank gas, with the front end up a bit; the point being to duplicate on-track conditions.
Re: How do you align the front end Street Strip Car` [Re: Kam*Kuda] #868810
12/01/10 04:46 PM
12/01/10 04:46 PM
Boise
Moparteacher Offline
Boise
Strip and street are two different alignments. They have different requirements.
Here's where to start.
Confirm chassis height is set. Equal side to side.
Adding weight to the seats will effect chassis height and the alignment, although it will be minor.
Confirm the rear tires are in line with the centerline of the car. It's called thrust angle.
You want zero thrust angle.
Steering gear needs to be centered. This centers the pitman and idler swing.
The centerlink should be parallel to the surface of the ground. If not, raise or lower the idler arm.
The following is for strip:
Camber should be zero.
Cross Camber should be zero.
Cross Caster should be zero.
Outer tie rods should be equal in height and equal in distance measured to the inside of the wheel.
The steering arm can be heated and bent to correct height and distance after Cross Caster has been set to zero.
Set toe to 1/16 to 3/16 toed in.
Re: How do you align the front end Street Strip Car` [Re: Moparteacher] #868811
12/01/10 05:42 PM
12/01/10 05:42 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I called around and found a shop that did work on "old" cars,,,,There was a old Mopar guy,,,that was well versed in aligning race cars,,did a great job,,,,,,
You might want to call around locally.........
Re: How do you align the front end Street Strip Car` [Re: 69CHARGERMD] #868812
12/02/10 03:25 PM
12/02/10 03:25 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
There is only one place that is local that does great front end work. Old school guys, with loads of experience. I trust their work but they are not race car guys.
Thanks for the specs.
Rob
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: How do you align the front end Street Strip Car` [Re: Kam*Kuda] #868813
12/02/10 03:28 PM
12/02/10 03:28 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
fyi these are my control arms, I do not think there is any adjustment available here
1654.5 Mustang
1955 Land Rover
Re: How do you align the front end Street Strip Car` [Re: Kam*Kuda] #868814
12/02/10 03:44 PM
12/02/10 03:44 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Adjust the 2 cam bolts (see the red arrows)
Keep the adjustments simple as the 1 st post states. 0 camber, .06-.09 toe in, and as much caster as posible
